975800 Posts in 138943 Topics by 6362 Members - Latest Member: Bmxflex November 19, 2024, 04:53 AM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  im lost past 1983 new school bottom bracket question
Author Topic: im lost past 1983 new school bottom bracket question  (Read 2790 times)
Offline lammychop
« on: July 27, 2011, 04:34 PM »
my boy has a mongoose mischief entry level bike its 6months old he wants to replace the opc with a 3 piece what bottom bracket do i need
mattuknc
Re: im lost past 1983 new school bottom bracket question
« Reply #1 on: July 27, 2011, 04:46 PM »
Any USA style sealed setup should fit it. Depending on the cranks axel size either 19mm or 22mm (19 is most common).  :daumenhoch:
(or you can get a USA to Euro converter and get a Euro bb set, but I didn't want to complicate things.  :))
Offline kev-s
« Reply #2 on: July 27, 2011, 04:48 PM »
according to custom riders it has a mid bottom bracket
http://www.customriders.com/prodshow.asp?prodid=12302&cat=57&parent=1010&sid=3
basicly a mid bottom bracket is like a normal usa bb but u dont use the cups so you fit the bearings straight into the frame :daumenhoch:
Offline lammychop
« Reply #3 on: July 27, 2011, 04:49 PM »
so the frame holes are all the same its just the spindals that are diferent is that right
Offline lammychop
« Reply #4 on: July 27, 2011, 04:51 PM »
the bike in the link is a newer version with a 3 piece on it allready his has only got the one piece
Offline kev-s
« Reply #5 on: July 27, 2011, 04:52 PM »
no the "frame hole" i.e frame's bottom bracket shell is the same size as a american bottom bracket sealed bearing without the cup, so just the bearing pushes into the frame with no cup
even the 2009 model uses a mid bottom bracket
the bike in the link has a 1 piece cranks
    * Frame: Mongoose Freestyle BMX Frame
    * Fork: Mongoose BMX fork
    * Handlebars: 2pc BMX Design
    * Front Hub: Mongoose 14mm
    * Rear Hub: Mongoose Freewheel Hub 13T
    * Rims: Alex 36H Front 48H Rear Rims
    * Brakes: U Brake with Gyro Cable Detangler
    * Tires: Mongoose designed tyres
    * Pedals : Platform
    * Cranks: 1pc 175mm Tubular crank
    * Sprocket: 36T
    * Mid Sealed Bottom Bracket
    * Saddle: Mongoose shorty padded saddle
    * Seat Post: Steel
    * Grips: Mongoose OG Grip
« Last Edit: July 27, 2011, 04:55 PM by kev s »
Offline oldtired
  • Dirty Old Man
« Reply #6 on: July 27, 2011, 04:57 PM »
didn't know you could fit a 1 piece in a mid bb  :LolLolLolLol:  learn something  new every day, ,, it says a tubular 1piece too which suggests its hollow? bit confusing that i think , unlikely to be hollow but, if so then its going to be lighter than a 3pc  although not as strong
« Last Edit: July 27, 2011, 05:36 PM by oldtired »
« Reply #7 on: July 27, 2011, 05:00 PM »
Yeah, but if it currently has a opc then it's an older frame with a US BB. I had one and gave it to Jaymz for his nephew when we had a whip-round and it had a US BB on it.
You need to know what crank you intend to put on it and send a pic and we can tell you what BB to get. Send a pic of the bike to so we can be sure.
Offline lammychop
« Reply #8 on: July 27, 2011, 05:00 PM »
ok bit confused  it doesnt take much
this is the crank im trying to fit
could someone give me a link to a bb that will work with it
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=280714197572&ssPageName=STRK:MEWAX:IT
Offline kev-s
« Reply #9 on: July 27, 2011, 05:06 PM »
opc cranks can be fitted to mid bottom brackets, best to put up a pic of the frame's bb just to be sure
jawbone cranks use a 19mm axle so u need a 19mm bottom bracket and your frame uses a mid bottom bracket according to custom riders website
so u need this 19mm bottom bracket
http://www.customriders.com/prodshow.asp?prodid=14051&cat=8&parent=1001&sid=3
« Last Edit: July 27, 2011, 05:14 PM by kev s »
Offline lammychop
« Reply #10 on: July 27, 2011, 05:09 PM »
ok here the currant bb
Offline oldtired
  • Dirty Old Man
« Reply #11 on: July 27, 2011, 05:12 PM »
Bargain   :daumenhoch: :daumenhoch:
Offline oldtired
  • Dirty Old Man
« Reply #12 on: July 27, 2011, 05:13 PM »
that one is a us bb
Offline kev-s
« Reply #13 on: July 27, 2011, 05:13 PM »
right that is a american bottom bracket, so the bike prob isnt 6 months old, maybe a couple of years
so u need this bottom bracket
http://www.winstanleysbikes.co.uk/product/21594/Profile_American_Standard_Cup__Bearing_Set
Offline lammychop
« Reply #14 on: July 27, 2011, 05:15 PM »
was defo new last christmas
Offline lammychop
« Reply #15 on: July 27, 2011, 05:18 PM »
so i need a 19mm american bb is that correct
Offline kev-s
« Reply #16 on: July 27, 2011, 05:19 PM »
strange that custom riders and a couple other sites show that the 2009 & 2011 has a mid bottom bracket in the spec list
maybe its a mistake by mongoose, when they released the spec list and it was ment to say american bottom bracket not mid bottom bracket
oh well your all sorted now :daumenhoch: :daumenhoch:
Offline kev-s
« Reply #17 on: July 27, 2011, 05:20 PM »
yes u need a 19mm american bottom bracket for those cranks :daumenhoch:
Offline lammychop
« Reply #18 on: July 27, 2011, 05:21 PM »
many thanks
Offline oldtired
  • Dirty Old Man
« Reply #19 on: July 27, 2011, 05:29 PM »
right thats old Lammychop's problem sorted, always get there in the end ,  :LolLolLolLol: ,    but  how do you fit a 1pc in mid bb ?
Offline kev-s
« Reply #20 on: July 27, 2011, 05:39 PM »
google tells me u cant due to the bottom bracket shell being too small to feed the 1 peice crank arm through
teach me not to believe everything i read  :LolLolLolLol: :LolLolLolLol:
« Reply #21 on: July 27, 2011, 05:42 PM »
Just a pic here's the mid bearings and the US sized (hop up kit) cups  they fit in :)
« Reply #22 on: July 27, 2011, 07:42 PM »
19mm axle to US BB size in a sealed unit - here's a well kept secret for you bud at £13.99 plus £1.99 postage and it's even black to match the frame and crank :daumenhoch:
It's EXACTLY the same as a Redline Flight one but badged as Diamond Back, even down to the part numbers, so why pay over twice that price :shocked:
http://www.ebay.co.uk/itm/bmx-bike-diamondback-sealed-bearing-bottom-bracket-bmx-/280701109987?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item415b1706e3
Bought half a dozen off this guy over the last few years and he's superfast delivery and spot on :daumenhoch:
Offline lammychop
« Reply #23 on: July 27, 2011, 09:32 PM »
nice one spen just bought one
« Reply #24 on: July 27, 2011, 09:48 PM »
You're welcome bud :daumenhoch:
