975838 Posts in 138948 Topics by 6379 Members - Latest Member: McChippy72 January 13, 2025, 05:49 PM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  whitewall tyres- what ones's and where from....
Author Topic: whitewall tyres- what ones's and where from....  (Read 455 times)
Offline dubber
« on: July 26, 2011, 05:50 AM »
Hi, been looking around for some whitewalls to go on my new white tuffs for the retro 09 freestyler, haro multisurface look to be as rare as! And expensive...had a quick look round I've seen Eclat ones on alans bmx and Animal Tom's on Ace bmx in the US..anyone had these or know of similar one's..
I like the 100 odd PSI tyres to take my 15st fat arse..lol..
Cheers,Paul
Re: whitewall tyres- what ones's and where from....
« Reply #1 on: July 26, 2011, 07:40 AM »
Hi Paul
To be honest with you the new white wall tyres will be great to ride on.........but not with your white flexy tuffs and you definately won't be able to run 100psi in them on Tuffs.  you'll be lucky to run 60psi in them and that'll be pushing it.
Tuffs aren't designed to have that higher pressures run on them and as they flex like fook you'll end up popping the tyres off your rims and hurting yourself.
« Reply #2 on: July 26, 2011, 08:01 AM »
^^what Rob said bud^^
When I first got into building everything had Tuffs but you can't run safely above 45 to 50 psi on them as they flex and then the tyre's off the rim and it all ends in pain.
If you want to ride ramps then you want high pressure ramp tyres and to do this you need spokes. I strip down any wheels I'm thinking of riding and re-lace them then get my lbs to final tension the shit out of them so I know they're safe to ride and the tyres protect them fine. Currently jumping the crap out of a set of Araya 7X's no worries with 70psi in my gumwall Dave tyres.
Oldschool tyres look great but also usually end in a trip to A&E!
Offline dubber
« Reply #3 on: July 26, 2011, 08:44 AM »
Thanks for the info, does the same apply for normal everyday riding,out with the kids etc??
« Reply #4 on: July 26, 2011, 08:52 AM »
be fine for cruising about on  :daumenhoch:
« Reply #5 on: July 26, 2011, 08:58 AM »
Again, what Rob said!
No problems with Tuffs for cruising and looking cool, just don't go all Hoffman on them and start jumping around in skateparks.... Like I did a few years ago!
Offline dubber
« Reply #6 on: July 26, 2011, 09:58 AM »
Mate,I'm too old for all that....thanks for your help chaps...tuffs and whitewalls for cruising it is then...
Offline MaD-RoK
« Reply #7 on: July 26, 2011, 10:28 AM »
I had some of these whitewalls on my old streetbeat rider, they were great for rolling around......
http://www.mailorderbikes.com/m8b639s301p2575/MICHELIN_Diablo_City_20_x_1_75_White_Wall_
« Reply #8 on: July 26, 2011, 12:17 PM »
I had a set of Michelin Diabolo
@ £6.99 each you cant go wrong
http://www.chainreactioncycles.com/Models.aspx'modelID=24929&utm_source=google&utm_medium=shopping&utm_campaign=Google-Products-UK
*EDIT Oh just like lee has posted!!! There you go a double recommendation, they cant be bad then!!!
twit twoo
« Reply #9 on: July 26, 2011, 10:30 PM »
Ive run 80-85 psi on tuffs with no problem. Ran it with a primo wall, but haro multisurface should be up to the job, they are a good solid tyre, but i suppose it depends if you are going to be backflipping over 12 virgins onto a 100m stretch of cobbles.
