975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 30, 2024, 02:14 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Paint Rubbing Off
Author Topic: Paint Rubbing Off  (Read 627 times)
jasbadboy
Paint Rubbing Off
« on: July 23, 2011, 04:06 PM »
Hello,
Can anyone suggest a sollution for this?
The crank is a redline 175 and the allen key bolt rubs on the bottom bracket. Have i fitted it correctly and have i got the correct size crank?
Offline john4130
Re: Paint Rubbing Off
« Reply #1 on: July 23, 2011, 04:13 PM »
you want a dome head bolt on it, if it still hits put a couple of thin shims between the bearings and the chainring to space it out a bit.
Offline kuwahero
    • Western Titans
« Reply #2 on: July 23, 2011, 04:41 PM »
are they OS redlines or NS twin pinch ones. If they are OS I can sell you a domed sprocket bolt that should sort out that problem
jasbadboy
« Reply #3 on: July 23, 2011, 05:18 PM »
they are original redline 175's single pinch. cool if i can buy a bolt off you.
Offline rick1970
« Reply #4 on: July 23, 2011, 07:43 PM »
Ouch  :shocked:
