975805 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 12:33 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  headset
Author Topic: headset  (Read 1605 times)
J4CK
headset
« on: July 18, 2011, 04:06 PM »
i have a raleigh burner f/f and was thinkin of puttin new school forks on it.
i know old school are 1" and new school around 1 1/8"?
i heard there are some threads on how to make them fit but cant find one >:(
can anyone point me in the right direction ;)
1mancity2
Re: headset
« Reply #1 on: July 20, 2011, 10:15 AM »
will a standard 1 1/18 headset fit a burner frame? if so thats all you need.
Re: headset
« Reply #2 on: July 20, 2011, 12:46 PM »
The forks may do but the headset obviously won't. The thread was on the museum and involved running loose bearings against the steerer tube. It was clever but extremely fiddly and difficult to maintain without caged bearings.
Can't remember who posted the link but hopefully this might jog someone's memory?
Re: headset
« Reply #3 on: July 20, 2011, 12:49 PM »
just dump the burner in the canal and get a proper BMX  ;)  ;D
Re: headset
« Reply #4 on: July 20, 2011, 12:54 PM »
Sometimes i wonder whether anyone actually listens to me. I told jack all this a few days ago, but said i couldnt find the thread and he should search it out.
And he never thanked me for the FREE frame i sent him
Re: headset
« Reply #5 on: July 20, 2011, 12:59 PM »
what was that?         did someone say something?  ???
 ;D
Offline Discostu
  • Two's Company
Re: headset
« Reply #6 on: July 20, 2011, 02:48 PM »
I have done this conversion to my 1989 pk ripper that has a 1" headtube. I used the cups from a tioga beartrap 2 headset. Along with the top bearing. I then purchased a Savage 1""1/8th headset from mr stodgy at the rad bmx shop. The lower savage 1"1/18th crown should fit fine on your forks. But be aware of the height of the collared part of the forks that it sits on. On my forks the cooler was an 1" tall so the forks had to have the collar area machined Down so it was the same height of the crown. Most forks I have seen don't have a high collar so it probably won't be a problem.  Now one of the bearing races in the savage headset will fit in the bottom beartrap headset cup but it wont move freely. I took the bottom cup and bearing down to my local engineering firm and asked them to whack it in a lathe and take of a few thousands of an inch from the inside if the lower cup so the bearing would rotate nicely. This is a five minute job so won't cost you much. Maybe a tenner max. Now the cups can be fitted to the frame the bottom bearing greased up. The crown tapped on to the forks along with the savage rubber seal which should fit perfectly into the bottom beartrap cup and look as though it belongs there. Now I can't remember which bearing race I used in the top beartrap cup. But it was either the other savage one or one of the beartrap ones. Anyway one of them will fit perfectly without any modification.  Then the remaining parts of the savage headset can be fitted as normal along with the later clamp around 1"1/8th stem. The whole thing will look correct and work well. I rode mine fir a bit and then tightened up the slack. It has been working great. So the parts you need are 1 x tioga beartrap 2 1" headset. 1 x savage 1"1/8th. Things that will need modifying- the lower beartrap 1" cup will need a minimal amount of machining to accept the savage 1"1/8th bearing. Other bits that may require modification. The collared area on your 1"1/8th forks that the lower crown sits on may need to be machined. You will know if it does by sliding the bottom beartrap 1" cup down the fork tube. If it doesn't go all the way down to the crown then the area will need to be machined or grinded away. This again is a minimal job to do. My Pk ripper will be at mk 11 if your about pm me and I will show you the modification. Cheers stu
HEYWOOD BMX
Re: headset
« Reply #7 on: July 20, 2011, 05:42 PM »
