975808 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 08:35 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  polish
Author Topic: polish  (Read 1646 times)
polish
« on: July 11, 2011, 11:51 AM »
bit more polishing done while waiting for mags to cook in colour - need to change mops as not 100% happy with finish   ::) will do crank and chain ring better - but that's polishing for you  :idiot2:
punkdSICO
Re: polish
« Reply #1 on: July 11, 2011, 01:52 PM »
Nice results!!  What are you using?  I recently got a Dremel which is pretty good but mainly for intricate/small polishing.
Ta,
Paul
Re: polish
« Reply #2 on: July 11, 2011, 06:38 PM »
bench grinder from a carboot = £4 and then take off the grinding wheels and change them for a set of polishing mops that were bought from ebay (you need four different ones and polishing bars and some lime ) check size of mops /polish wheels before hitting buy it now button
learn on a couple of bit of metal/steel/alloy/chrome - heat and time of day can change the way it polishs up - keep every thing clean
put a soft matt under the bench grinder - i use a work horse and have it bolted down - the matt will sofern the item when it pings out of your hands and onto the floor  ;D
have fun - watch you eye and wear some leather gloves that can take the heat as a item will get bloody hot  >:D
cheers B  :D
Offline oldtired
  • Dirty Old Man
Re: polish
« Reply #3 on: July 11, 2011, 09:44 PM »
nice do like shiney ally me  :daumenhoch:
 ;D  switch of the grinder before bending over to pick up the bit , that way you dont end up stopping it with your head  :LolLolLolLol: :LolLolLolLol:     :-[ :-[   :-X
« Last Edit: July 11, 2011, 09:47 PM by oldtired »
Offline HARORIDER
Re: polish
« Reply #4 on: July 11, 2011, 09:49 PM »
soft cotton g mop and blue polish to finish off and use vienna lime to clean off the residue and use a mop dresser to clean off excess compound  :daumenhoch:
Re: polish
« Reply #5 on: July 12, 2011, 12:05 AM »
