975884 Posts in 138950 Topics by 6383 Members - Latest Member: moley147 February 18, 2025, 01:16 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  mini BB removal
Author Topic: mini BB removal  (Read 1947 times)
Offline TELLIS302000
mini BB removal
« on: June 29, 2011, 11:17 PM »
Righty.....as the title says!
Do you need a special tool to split the BB on these mini's? It doesnt have lock nuts etc....
Cant say ive done one like this before!
Offline kuwahero
    • Western Titans
Re: mini BB removal
« Reply #1 on: June 29, 2011, 11:22 PM »
what does it look like. pics would be good
Re: mini BB removal
« Reply #2 on: June 29, 2011, 11:29 PM »
here ya go.
curtispro
Re: mini BB removal
« Reply #3 on: June 30, 2011, 08:29 AM »
That looks like a sealed cartridge unit, you will need a special tool to remove that, it will come out in one piece,  something like this you just need to get the right one  :daumenhoch:
http://www.google.co.uk/products/catalog?q=bottom+bracket+removal+tool&hl=en&prmd=ivns&resnum=1&bav=on.2,or.r_gc.r_pw.&biw=1440&bih=837&um=1&ie=UTF-8&tbm=shop&cid=2603711978387087716&sa=X&ei=eSUMTtadC8O98gOtnLmeDg&ved=0CFkQ8gIwAQ
Offline diesel
Re: mini BB removal
« Reply #4 on: June 30, 2011, 09:09 AM »
Your lucky that should be relatively easy to find a tool for.
I've been looking for a tool to fit this one for about a year now:
1mancity2
Re: mini BB removal
« Reply #5 on: June 30, 2011, 12:45 PM »
Diesel are you using the BB again or getting a new one, if fitting a new you can get them out using a stillson wrench.
Re: mini BB removal
« Reply #6 on: June 30, 2011, 01:20 PM »
Antony - that's a standard tool so your LBS should be able to remove that easy.
Failing that get it into the fix-it gazeebo at MK and I'll get it out for you as I think Hootski's treasure chest of tools has one in there to fit it :daumenhoch:
Re: mini BB removal
« Reply #7 on: June 30, 2011, 01:31 PM »
If you get a tool and have a go, remember that the drive side is a reverse thread  :daumenhoch:
Offline diesel
Re: mini BB removal
« Reply #8 on: June 30, 2011, 01:42 PM »
I would destroy it but I'm concerned I won't find a replacement  :'(
Re: mini BB removal
« Reply #9 on: June 30, 2011, 01:54 PM »
Whats the bb shell width and spindle length?
Offline diesel
Re: mini BB removal
« Reply #10 on: June 30, 2011, 02:07 PM »
I'll have to check that one
Re: mini BB removal
« Reply #11 on: June 30, 2011, 02:08 PM »
I would imagine its 68mm shell and 108 or 110 spindle width, both are readily available  :daumenhoch:
Re: mini BB removal
« Reply #12 on: June 30, 2011, 08:17 PM »
big hammer and chisel  :knuppel2:
Re: mini BB removal
« Reply #13 on: June 30, 2011, 08:25 PM »
Bought a tool for it.
Damn it was tight (seized), had to get some heat on it and put the tool in the vice and basically turn the whole frame.
Its out now though.
Shimano bb-un52 needed, easily available on the net unless anyone here has one for sale??
Offline Dingobmxer
Re: mini BB removal
« Reply #14 on: June 30, 2011, 08:26 PM »
Top one is a standard fitment for a shimano tool and about a fiver for a shop to take it out for ya
Dan bring the frame with you next time you are up and we can take it to sShokwave to get it out  :daumenhoch:
Dingo
Offline diesel
Re: mini BB removal
« Reply #15 on: June 30, 2011, 09:05 PM »
Cheers Mark, will give you a shout
The spindle is 125mm
The Bottom Bracket measures 65mm
Anyone any ideas what might fit this?
1mancity2
Re: mini BB removal
« Reply #16 on: July 01, 2011, 06:57 AM »
Re: mini BB removal
« Reply #17 on: July 01, 2011, 10:55 AM »
I would say that the BB you have in there aint for single speed but for a triple, that spindle width would put the chainline out by a mile, as for the shell width 68mm should be fine.  Have you tried some cranks on there to see how it shapes up?
Offline diesel
Re: mini BB removal
« Reply #18 on: July 01, 2011, 11:31 AM »
I have some nice 165 cranks for it and they seem to line up fine, although now that you've said that I'm going to double check.
I had a chat with SBD a little while ago about masking it for spray - So I'm thinking I might risk it in the oven with the BB attached
As It works well I'm not sure I really want to thinker about with it too much.....  ???
1mancity2
Re: mini BB removal
« Reply #19 on: July 01, 2011, 12:16 PM »
Wet paint it no need for the oven then  :daumenhoch:
