975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 11:40 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Spen's marvellous vibrating.... steady...... "Sanding Machine"! ;)
Author Topic: Spen's marvellous vibrating.... steady...... "Sanding Machine"! ;)  (Read 914 times)
Clean
Before & after....
Thanks, Spen, mate.....  :smitten:
 :4_17_5:
shine sides FTW!!
 :shocked: ::)  ;D  :2funny:
good work - I've been trying to do some by hand before sending em away to be built up, might have a go with a sander once I get em back
Offline poolysheriff
is it easy to do  ???
i,ve got some red araya's that could do with the worn sides cleaned up like that  :daumenhoch:
Offline Darren KAP
   Yes it's very easy bud , i start with    p180 grit  then p240   then p400  on an air sander   then wet flat  with  a block using  800 then 1000   then 1500     then finish off with 2000 super fine  after all that i gently clamp in the vice using some cloths too ,     i then use g3 compond and a buffer and if you don't  rush the finish will be like a mirror  :smitten: :smitten:
 I probably got a bit carried away but the finished result is well worth the effort    :daumenhoch:
« Last Edit: June 26, 2011, 09:29 PM by Darren K.A.P »
Darren.... "I probably got a bit carried away"........ fook me, do you think so? I only gave Rich a 100 and 120 grit pack of pads :LolLolLolLol:
Richard my boy, they look great - you truely are embrasing resto mate :daumenhoch:
Now then, I wonder what bike they're going on eh ::) :2funny:
i could send you one of me flip flops so you can use as a rubbing down block  :LolLolLolLol: :LolLolLolLol: :LolLolLolLol: :LolLolLolLol:
better than wearing them on your feet  :daumenhoch:
