975810 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 12:35 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Kashi Aero Guts
Author Topic: Kashi Aero Guts  (Read 941 times)
ThisBitterPill
Kashi Aero Guts
« on: June 17, 2011, 09:24 PM »
Bought a repop Kashi recently and found out they don't make repop guts....  >:(
Since then I've struggled to find some some Allen Key guts (at a reasonable price anyway!)
So I thought I'd have a go at making a set from a standard set of guts and here is the result!
I'm really pleased with how they turned out, despite the frustration involved with trying to reduce the bar enough to fit under the very narrow Aero!
I'm not sure I'd want to use them for a rider but for my build they will be fine....
« Last Edit: June 17, 2011, 09:28 PM by ThisBitterPill »
Re: Kashi Aero Guts
« Reply #1 on: June 17, 2011, 10:30 PM »
looks good, are you getting to lets us know how you made them?
ThisBitterPill
Re: Kashi Aero Guts
« Reply #2 on: June 17, 2011, 10:46 PM »
I took a standard set of guts which had the usual nut fixings....
I drilled out the outer parts of the clamps to take an M8 Sleeve Nut (which were a right pain to find!) and cut the threaded bar down accordingly....
But like I said, the Aero is very narrow and so I had to remove quite a lot of the thread from each end of the bar (hence me not trusting it on a rider)
I should really have recessed the outer parts so the Sleeve Nut sits flush, but I couldn't make the bar any narrower so I left it sitting proud....
sid1972
Re: Kashi Aero Guts
« Reply #3 on: June 17, 2011, 11:41 PM »
looks awseome - didn't the early guts have nuts and bolts?
ThisBitterPill
Re: Kashi Aero Guts
« Reply #4 on: June 18, 2011, 10:15 AM »
 :shocked: Don't tell me that!
trasher
Re: Kashi Aero Guts
« Reply #5 on: June 18, 2011, 11:32 AM »
yep the early ones had nuts ,then the later ones had the allen nut  :daumenhoch:
not sure on the change over date , but going by martins , he has pictures of both dated at 1981
http://martin-bike.com/BikeBuilder/Seats/index3.html
ThisBitterPill
Re: Kashi Aero Guts
« Reply #6 on: June 18, 2011, 06:50 PM »
Ah that's ok....My build is circa 1985....Phew!  :)
Re: Kashi Aero Guts
« Reply #7 on: June 18, 2011, 06:52 PM »
impressed well done they look very nice  :4_17_5:
monkian
Re: Kashi Aero Guts
« Reply #8 on: June 18, 2011, 08:33 PM »
Great job that mate 8) :daumenhoch:
Always a shame when the gut nuts force the sides out on a good looking seat out.
