975755
TattooedYorkie
September 21, 2024, 06:25 PM
cable clip ?
Topic: cable clip ? (Read 627 times)
BENDYCAT ELEVENTEEN
Berm Worm
"Click here for link"
cable clip ?
June 17, 2011, 12:36 AM »
What cable clips fit on a 83' gusset goose ?
i had a set that i thought would work but is 3-4mm to big - also have another set that would fit oval tubing and that is the lager of the two ?
am i missing some thing ?
cheers B
1mancity2
Re: cable clip ?
June 17, 2011, 07:11 AM »
31.8 is to big only way I got them to fit was to turn the lock nut the other way then cut down the threaded screw, worked a treat
cable clip ?
