* SAME QUESTION THREAD HIJACK * 84 low flange suzue hubs with 36h 81 Araya rims ... what size spokes would I need?Cheers
Quote from: NORTY40 on June 04, 2011, 02:09 PMBrett meant 14 gauge mate If your asking what length you require then :If it's to a Araya 7X style rim :184mm 3 cross lace 195mm 4 cross lace I dont think you get 195mm, but 194mm works.
Ed , Low flange suzue to Araya 7X rim :3 cross lace 190mm4 cross lace 196mm you would get away with 194mm though Ed Quote from: Glen on June 04, 2011, 02:27 PMQuote from: NORTY40 on June 04, 2011, 02:09 PMBrett meant 14 gauge mate If your asking what length you require then :If it's to a Araya 7X style rim :184mm 3 cross lace 195mm 4 cross lace I dont think you get 195mm, but 194mm works.You can get what you want if you get them cut to size , your right though 194mm is more readily available
Joff - I don't think they are 7x rims? will they be the same?Cheers bud1.EdQuote from: NORTY40 on June 04, 2011, 07:01 PMEd , Low flange suzue to Araya 7X rim :3 cross lace 190mm4 cross lace 196mm you would get away with 194mm though Ed Quote from: Glen on June 04, 2011, 02:27 PMQuote from: NORTY40 on June 04, 2011, 02:09 PMBrett meant 14 gauge mate If your asking what length you require then :If it's to a Araya 7X style rim :184mm 3 cross lace 195mm 4 cross lace I dont think you get 195mm, but 194mm works.You can get what you want if you get them cut to size , your right though 194mm is more readily available
