975810 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 02:42 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Polishing - any cool hardware to make it easier?
Author Topic: Polishing - any cool hardware to make it easier?  (Read 918 times)
punkdSICO
« on: May 28, 2011, 11:45 PM »
Any good tips for polishing machinary to make standard polishing a bit easier?  Nothing expensive or bulky; I just want to take a bit of the crunt work out of polishing small components and frames..
thanks,
Paul
Re: Polishing - any cool hardware to make it easier?
« Reply #1 on: May 29, 2011, 12:19 AM »
You can get drill polishing attachments, I would recommend buying a cheap electric drill for use just for polishing this way you don't screw up a good drill.
If you have a bench grinder then you can get a bench polishing kit, this is more powerful and gives a better finish.
« Reply #2 on: May 29, 2011, 12:21 AM »
Starter kits for Drill or bench mount here
http://www.thepolishingshop.co.uk/acatalog/Polishing_Kits.html  :daumenhoch:
p1nell
« Reply #3 on: May 29, 2011, 07:01 PM »
same as what Stibbs and Norty40 said :daumenhoch:
Hootski70
« Reply #4 on: May 30, 2011, 11:29 PM »
Screw fix do a home brand bench grinder and a cheap polishing mop set , great value .
