975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 08:44 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Pedal Bearings (SR Custom M's)
Author Topic: Pedal Bearings (SR Custom M's)  (Read 931 times)
« on: May 26, 2011, 08:48 PM »
Hi guys, i'm having trouble building my pedals back up, did it once but started to get a knock when riding/click.
I can sit the bearings on to the spindle with ,mass amounts of grease and can fit the spindle to the cage, but it's sitting the bearinggs on the nut and fitting it on to the spindle without them falling off and having to start again.
What am I doing wrong? Is there a technique I need to know about?
Cheers Dan.
Offline john4130
Re: Pedal Bearings (SR Custom M's)
« Reply #1 on: May 26, 2011, 08:55 PM »
put the grease on the bearing cup on the pedal body, sit the bearings in the grease then install the axle, grease the other side of the pedal body then stick the bearings in there. then stick the cone back on washer and locknut.
« Reply #2 on: May 26, 2011, 08:59 PM »
Cheers John, i'll give it a bash.
« Reply #3 on: May 26, 2011, 09:39 PM »
Gave that up as a bad job, my sausage fingers + bad temper = binning the white pedals off and fitting the black ones, not in keeping with the look of the bike but at this stage when I need the bike on Sat, I really can't be 4rsed, cheers anyway John.
Offline john4130
« Reply #4 on: May 26, 2011, 11:36 PM »
i could sort them for you if you wanted to stick everything in a bag and post them off to me.  :daumenhoch:
