0 Members and 10 Guests are viewing this topic.
Thanks for all the comments all , O am one lucky s.o.b Waza its a 79 and yes these were before the normal pk's, and before this was the JU-6 "Jeff Utterback" the same top tube but without the brace.
Quote from: kungfunky on May 25, 2011, 08:37 PMThanks for all the comments all , O am one lucky s.o.b Waza its a 79 and yes these were before the normal pk's, and before this was the JU-6 "Jeff Utterback" the same top tube but without the brace.not quite so, the ju-6 came in both round and floval top tube versions. the round tt pk came after the original floval tt pk but only had a short production run, it only came about because the factory ran out of the tt floval tubing (they were made in the same factory as race inc) so swapping in the tt was easy when stocks of floval tt tubing became available again production reverted to the original floval design.
Quote from: 58delray on May 26, 2011, 09:41 PMQuote from: kungfunky on May 25, 2011, 08:37 PMThanks for all the comments all , O am one lucky s.o.b Waza its a 79 and yes these were before the normal pk's, and before this was the JU-6 "Jeff Utterback" the same top tube but without the brace.not quite so, the ju-6 came in both round and floval top tube versions. the round tt pk came after the original floval tt pk but only had a short production run, it only came about because the factory ran out of the tt floval tubing (they were made in the same factory as race inc) so swapping in the tt was easy when stocks of floval tt tubing became available again production reverted to the original floval design.yes you are correct, but the JU-6 was floval and no gussetand its a quad not an str 1but nice round tube ripper there
Thanks for the compliments all and Spen I need to start saving for that
Quote from: kungfunky on May 26, 2011, 04:29 PMThanks for the compliments all and Spen I need to start saving for that One of the toughest things to find for any era correct build , NOS 1979 air ! .......
