976208 Posts in 138989 Topics by 6419 Members - Latest Member: BMXBoyBrookie March 25, 2026, 10:26 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Pro Class Rim Strips
Author Topic: Pro Class Rim Strips  (Read 2558 times)
« on: May 20, 2011, 10:03 PM »
Right guys, i've hit a bit of a snag tonight fitting a new 'homemade' set of rim strips on my Pro Class rims. The problem being that I wanted to change my colourway ready for the Berm thrash in Blackpoll next weekl so I removed my tyres to see what the existing ones were.
I discovered that my mate that I got the bike from had used gaffer tape, so I tried the same and failed. The main problems I faced were it moving about all the time so I had to ad tabs around the rim to help it sit snug, but when I fitted the tyre/tube and pumped up, the tape edges on 2 of the holes popped through where it had moved slightly.
I could keep trying and tabbing till I get it right, but if you guys can offer a solution and/or any tips, it will save me a lot of time and stress (swearing etc).
Cheers Dan.
Re: Pro Class Rim Strips
« Reply #1 on: May 20, 2011, 10:30 PM »
Just go round the inside of the rim carefully with PVC electrical tape a few times dan being careful to keep the foil ribbon central as you do. If you got the 19mm foil ribbon stuff I suggested it should be no problem at all as it's bigger than the hole by a few mm. Don't just put tabs of tape though, go right round the rim twice in one long strip  overlapping the edge of the foil each side  :daumenhoch:
Hope that makes sense  :D
« Reply #2 on: May 20, 2011, 11:02 PM »
i'll give it a try tmrw john, cheers mate.
« Reply #3 on: May 20, 2011, 11:05 PM »
1mancity2
« Reply #4 on: May 20, 2011, 11:13 PM »
I would love to try this but need wheels to try it on....... John?????
« Reply #5 on: May 21, 2011, 12:02 AM »
No chance Al  :LolLolLolLol:
« Reply #6 on: May 24, 2011, 04:53 PM »
I used these in the end just in case anybody struggled with gaffer/pvc tape as I did, they fit really tight and snug and obviously I turned them inside out to hide the print through the rim holes.
http://cgi.ebay.co.uk/Kink-BMX-Logo-Rim-Strips-Tape-Pair-White-/220759991641?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item3366522559
« Reply #7 on: May 26, 2011, 12:17 AM »
Go to a local craft/materal shop and buy ribbon.  They do it in loads of different colours, sizes and materials.
I used some on my old retro Quadangle...
steve
« Reply #8 on: May 26, 2011, 02:13 AM »
i have chrome sticky back plastic vynil, that i can cut to any size
-i have silver
gold -not mirror though
bronze
plus any other colour under t'sun
leave it on the paper backing and its quite thick.
Offline Pooch
  • funny you should say that..
« Reply #9 on: May 31, 2011, 08:55 AM »
http://bmxmuseum.com/forums/viewtopic.php?pid=2735131#p2735131 think I did this right!!!Tried to copy this over!!! :)
Griff loves BUM..
Offline Pooch
« Reply #10 on: May 31, 2011, 08:58 AM »
It worked!! Few!!! :daumenhoch:
Griff loves BUM..
