975805 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 05:38 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Skyway mags/bleaching/polishing/hubs and axle build
Author Topic: Skyway mags/bleaching/polishing/hubs and axle build  (Read 6489 times)
« on: May 18, 2011, 11:12 PM »
I posted this on the burner sites and thought that some of you may like to see as well  :wink:
Have finished Phils skyway mags - bleach white and polish hubs (not easy to keep clean when polishing with the white mags )
pictures on how i got on +
some one on the other side asked about which nuts and bits go where - i thought i would also put it up on here as well to see if it can help any one as well
how i got them
don't know what the stain was ? hard to shift
then bleached
then polish hubs by hand
so take one polished hub with nothing in it
right now gently tap the bearing cup in place this has the bearing cage in there
now grab some grease and smear enough in there - cocktail stick pushes it between the bearings nicely (the word is c0cktail not sh!t stick)
now grab your nuts and bits  :shock:
put your cone nut on the axle - this is how it looks, as in fits onto the bearings
on the front axle you need to have it the same length each side - the rear you have to play around with
next is your cone nut washer nut - this will tighten up against the cone nut - now each side will tighten up against the bearings - this has to be enough for the axle to spin and not wobble/knock, but not too tight that the bearing can't turn and wear away - now this is not the easy job that it sounds and one that you learn over time - the grease is fresh and will take a little time to warm up and spin faster - it is a good idea to return to the axle and nuts to check how loose it has become and if it needs tightening again
how to tighten - you need two tools that fit the cone nut and the washer nut - keeping the cone nut still with the tool turn the washer nut to tighten it - just before it comes to a stop turn the cone nut tool - this will stop it from crushing the bearings and allow a bit of slack (but not too much) you may have to undo and redo it a couple of time before you get it perfect (good luck)
now put on the washer and then the outer nut - you can see the gap and where the rear drop out will sit - you can put extra washers on the inside of the drop out to fill out, as not every frame has the same size at the back - size of axle / cone nuts / washers / nuts ~ can be different sizes to each build and set up
if you are sending out a set of wheels - do the nuts up to the hub or they can come loose and fall off and out of a hole in the box
get Alice to check them out
cloudy day - bugger as would look better in the sun
hope this helps all
cheers B ;)
Offline bigfatolly
Re: Skyway mags/bleaching/polishing/hubs and axle build
« Reply #1 on: May 18, 2011, 11:19 PM »
Nothing better than a pair of white alloy hubbed tuffs,great work :daumenhoch:
« Reply #2 on: May 18, 2011, 11:20 PM »
Looking factory fresh :smitten:
Offline WINI
  • Sheeping it real ;-)
« Reply #3 on: May 18, 2011, 11:21 PM »
Awesome job there mate.  Ive done a couple of pairs of whites recently and they come up lovely after the bleach.  Was this a new rebuild axle kit?  Need a couple of sets as my threads are totalled.  I know I can get em from Rini but do you know if you can get em in the UK?
Nice job  :4_17_5:
« Reply #4 on: May 18, 2011, 11:30 PM »
The Axles came with the mags for me to do - one is a original axle and one is a standard axle - both work in the mags
i have a standard rebuild axle kits coming up for sale real soon - this will allow you to have a standard nut or some thing different and it doesn't mean you have to track down skyway size nuts  ;)
pic's to follow  ;)
cheers B  ;)
Offline WINI
« Reply #5 on: May 18, 2011, 11:48 PM »
pic's to follow  ;)
cheers B  ;)
Put me down for at least a couple mate!  The Skyway rebuild kits are cheap enough but then you add postage and the worry of shipping from the US and......
Offline rick1970
« Reply #6 on: May 19, 2011, 06:16 AM »
Nice job there mate, put me down for two axel kits too when they come in cheers  :daumenhoch:
« Reply #7 on: May 19, 2011, 09:21 AM »
Lovely job B, now come round mine and clean up my nuts can you  ;D :D
« Reply #8 on: May 19, 2011, 05:40 PM »
I heard your nuts were always too tight, is that true?  :LolLolLolLol:
Offline Redline
« Reply #9 on: May 19, 2011, 05:57 PM »
Fabulous job there fella  :4_17_5:
Have to say if it was me though I would have left the alloy hubs lookin dull as they were never polished back in the day  :-X
« Reply #10 on: May 19, 2011, 09:35 PM »
Bostin is that arr kid  :coolsmiley:
« Reply #11 on: May 19, 2011, 10:41 PM »
It was asked to be that way - but i like it to show n' bling  >:D
all sale please post and pm in sale section thread  ;)
Offline monkeybat
« Reply #12 on: May 27, 2011, 11:25 AM »
What a coool Site "White Skyway Tuffs" great how to.
Offline Macmania
« Reply #13 on: May 27, 2011, 05:24 PM »
Great job B  :daumenhoch:
Your quality control assistant looks well sweet.
Wanted: Anything MT Racing
« Reply #14 on: May 28, 2011, 09:26 AM »
she's a pain in the but  ;D  it's that ball that she won't leave alone  ::) but she does know her biscuits and can tell if a skyway has been resto'd and built well  :daumenhoch:
punkdSICO
« Reply #15 on: June 08, 2011, 08:02 PM »
Gorgeous wheels!
btw, what is the central bit that goes through the flanges?  This picture shows it best:
Is it structural (looks crumpled in this picture) or, as I suspect, just there to contain grease etc from the central spindle??
ta,
Paul
« Last Edit: June 08, 2011, 09:51 PM by punkdSICO »
1mancity2
« Reply #16 on: June 08, 2011, 09:07 PM »
Top work as always Bendy,  :4_17_5:
a note on the rear axle I always take just the none freewheel side nuts and cone out so that the axle is always right when you put it back.  :daumenhoch:
« Reply #17 on: June 09, 2011, 08:29 AM »
A nice bleachin'  ;)
