975801 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 20, 2024, 05:48 PM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  FITTING SKYWAYS TO A BMX WITH 14MM DROPOUTS
Author Topic: FITTING SKYWAYS TO A BMX WITH 14MM DROPOUTS  (Read 630 times)
Offline HARORIDER
« on: May 17, 2011, 04:19 PM »
as skyways have 10mm axles would it be ok to just put them in and tighten up or use a 10-14 axle convertor? trouble is i've only seen threaded versions which do not fit the skyway thread-anyone done this already? what did you do?
Paul  :daumenhoch:
Re: FITTING SKYWAYS TO A BMX WITH 14MM DROPOUTS
« Reply #1 on: May 17, 2011, 04:37 PM »
get the little washers that convert 10mm to 14mm, cheap enough
Offline HARORIDER
« Reply #2 on: May 17, 2011, 04:48 PM »
where from :-\  :daumenhoch:
Offline HARORIDER
« Reply #5 on: May 17, 2011, 09:35 PM »
cheers guys  :daumenhoch:
spesh
« Reply #6 on: May 18, 2011, 08:33 PM »
i have a full set of front and rear axle converters (threaded) specifically for skyways 36/24 tpi
i had them on my haro zippo after using washers but they kept slipping in the drop outs so i bought the converters
as it was a rider
pm me if your interested :daumenhoch:
