975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 02:31 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Laced my 1st wheel but......
Author Topic: Laced my 1st wheel but......  (Read 3227 times)
Offline Jamroll
« on: May 11, 2011, 03:38 PM »
Cant lace the other  :knuppel2:
Followed the stickie on wheel lacing and had know problems at all  ::) Araya 7x laced to Bully hubs with 184 spokes.
The Rear was the one i managed to get laced up, trying to do the front and i'm finding that when i start crossing the spokes but half way round i not able to get the spoke to the nipple...I'm bout 2mm short  :-\
Now I've taken them apart 3 times now tried not puttin as many turns on the spokes when tightening, tried puting more turns on to try and pull the hub in a little but no luck.
\Am i missing something really straightforward ??? Same rims, same hubs, same spokes out the same packet as the rear i managed to do.
Help please Radsters
Al
Offline wildon
Re: Laced my 1st wheel but......
« Reply #1 on: May 11, 2011, 03:39 PM »
if the hubs are the same size there should be no problems at all .. funny that  ???
Offline Jamroll
« Reply #2 on: May 11, 2011, 03:42 PM »
I Know it doin my fookin head in  :uglystupid2: ! Done the rear last night and tried to do the front as well but was gettin tired so i guessed i'd made a simple error but have had another two goes today and still no joy  :-[
xGoose
« Reply #3 on: May 11, 2011, 03:55 PM »
Hub flanges same size?
Are the spokes on the front and rear the same length? (might be hard for you to tell as you've laced the rear). You might have had a different lacing pattern on the front (1x 2x 3x or radial?).  ;)
Have you got a pic of them before you delaced them?
« Last Edit: May 11, 2011, 03:58 PM by x-600se »
Offline Jamroll
« Reply #4 on: May 11, 2011, 03:58 PM »
Are the spokes on the front and rear the same length? (might be hard for you to tell as you've laced the rear). You might have had a different lacing pattern on the front (2x 3x or radial?).  ;)
Yup both hubs sized the same, spokes all out the same packet (ashi chrome 184's) and doing the front the same as the rear 3x  :-[
xGoose
« Reply #5 on: May 11, 2011, 04:04 PM »
It sounds like your building fresh wheels rather than taken them apart to clean and then relace is that right?
The only other thing I can think is that front hub flanges can be further apart than rear hub flanges and it might make that much difference by the time you get halfway round the wheel? Someone may be able to confirm it?  :-\
« Last Edit: May 11, 2011, 04:22 PM by x-600se »
Offline Jamroll
« Reply #6 on: May 11, 2011, 04:09 PM »
The only other thing I can think is that front hub flanges are further apart than rear hub flanges and it might make that much difference by the time you get halfway round the wheel? Someone may be able to confirm it?  :-\
Yeah fresh wheel build dude, looking at the hubs they look the same width, but i guess a mm out or so could make the difference.
Snav - tried that already but i guess i gonna give it another go now  :LolLolLolLol:
« Reply #7 on: May 11, 2011, 04:56 PM »
Sounds like you're 1 hole out on the other side bud. Strip them from the second side and re-lace from scratch moving one hole forwards or backwards?
« Reply #8 on: May 11, 2011, 05:37 PM »
I'd go with that, so easy to do too  :-[
motomagII
« Reply #9 on: May 11, 2011, 06:12 PM »
i think yoiu need 186 for them really .the hub diameter will be different from front to back hubs hence the shortage .
« Reply #10 on: May 11, 2011, 07:45 PM »
Yeah, gotta admit I use 186's to lace small flange to 7X in a 3X :-\
Offline Betty
« Reply #11 on: May 11, 2011, 08:15 PM »
Spen's probably right...  :daumenhoch:
Been there... done that...  :-[
2 minutes turkish...
« Reply #12 on: May 11, 2011, 08:40 PM »
I use 192s for Suzue small flange to 7xs :daumenhoch:
Offline Jamroll
« Reply #13 on: May 12, 2011, 11:49 AM »
Tried again last night and still no joy, gonna try and get some 186 ashi spoke...rare as though i guess.
I've got some 194's  would they be to long ?????
xGoose
« Reply #14 on: May 12, 2011, 11:54 AM »
Have you tried using an ERD (effective rim diameter) spoke calculator yet, that might help. ;)
Just google erd spoke calculator, there are loads of them.
Offline Gnarlyscoots
  • BANNED
« Reply #15 on: May 12, 2011, 12:21 PM »
Try this link bro  :daumenhoch:
http://bmxmuseum.com/forums/viewtopic.php?id=241229
It might help ya  :coolsmiley:
BANNED
Offline Jamroll
« Reply #16 on: May 12, 2011, 12:48 PM »
Offline Jamroll
« Reply #17 on: May 12, 2011, 02:11 PM »
If i used 194mm spokes and do 4X would this work?
If i do do 4X is it, under, under, over, under??? and when lacing wot else do i need to do differently?
Al
« Reply #18 on: May 12, 2011, 02:19 PM »
The thing is it is very hard for people to tell you what spoke size to use.  I have now laced 100's of wheels (I also wrote the how to guide on here) and I always use a spoke calculator as that is the only way to know 100% what size spokes to use.
You will need to take measurements of both hubs as lots of rear hubs have different measurements than the front.  Also you need to measure the ERD (as x-600se mentioned).
I have built so many wheels where the front uses 182mm and the rear 188mm.
Offline Jamroll
« Reply #19 on: May 12, 2011, 02:25 PM »
Stidds,
I followed your how to guide on here  :daumenhoch:
Wot would i need to do differently to lace 4x?
Offline Dannywhac
  • return of the whac
« Reply #20 on: May 12, 2011, 02:25 PM »
I use this:
Buy yourself one of these:
http://cgi.ebay.co.uk/6-Inch-150-MM-Digital-Vernier-Caliper-Carbon-Fibre-/300539288266?pt=UK_Measuring_Tools_Levels&hash=item45f9899aca
Have a look here for the calculator:
http://www.wheelpro.co.uk/spokecalc/
And here for the A,B,C,D etc help:
http://www.wheelpro.co.uk/spokecalc/help2.html  - edit - see the 'help' button on that page (will show you how to measure all the A,B,C etc) - linky doesn't take you to it for some reason.....
And then google your rim name/tpye and 'ERD'
« Reply #21 on: May 12, 2011, 08:49 PM »
Stidds,
All you need to do to lace 4x is instead is lace the spoke over 3 spokes and under 1, instead of over 2 and under 1 for 3x.
