975829 Posts in 138947 Topics by 6376 Members - Latest Member: The Carrot Cruncher January 01, 2025, 03:56 PM
RADBMX.CO.UK  |  New School BMX 2004 - Now  |  New School Park, Street & Dirt  |  Bit of a swap around
Author Topic: Bit of a swap around  (Read 2333 times)
Offline Betty
« on: May 08, 2011, 09:55 PM »
Built a Dirtbike a couple of weeks ago ever since building it my son has pestered me for my old LTF frame so....
That meant his ATF was going spare.... not anymore...
Covered in lacquer peel/rust...  >:D
And the F has gone awol.... S&M AT...  :D
Anyone want a Dirtbike?...  ???
2 minutes turkish...
Offline Betty
Re: Bit of a swap around
« Reply #1 on: May 08, 2011, 10:19 PM »
There ya go Glen, only rode it twice...  :-[
He'll probably kill the LTF in no time, so the Dirtbike is back in its box for now
Offline Peter J
  • I have issues
« Reply #2 on: May 08, 2011, 11:38 PM »
Bloody ell Mark  :shocked:
That L.A.F will last 5 mins with old (or young) Crank Snapper Liam  >:D
Offline fugazi
« Reply #3 on: May 09, 2011, 12:47 PM »
What brake are You running on the back of the ATF & is it a nice fit on the mounts or does it flop about? I've tried 4 different brakes on mine & they're all loose on the mounts.
Offline Betty
« Reply #4 on: May 09, 2011, 09:55 PM »
Got a fly brake on it dude, know what you mean about the mounts, bit poor design imo...  :-\
The brake arms do have a little bit of wobble, i'll let you know how it goes when i've been the park... tomorrow hopefully...  :daumenhoch:
« Reply #5 on: May 09, 2011, 10:04 PM »
Was that LTF frame the one you rode in blackpool? If so  :smitten: so much better looking in the flesh
Offline Betty
« Reply #6 on: May 09, 2011, 10:24 PM »
Yeah thats the one, the poor lighting in that place flatters it though, trust me its a right mess in proper daylight!
Still dubious about Liam using it, i've had it 2 years it's got sentimental value.... sad i know...  ;D
Offline fugazi
« Reply #7 on: May 09, 2011, 11:14 PM »
It's got to be the worst design of a removable mount I've come across! I've had problems with the bolts coming loose as well, got some stainless countersunk bolts coming so I can try an odyssey evo 2 on there, and some red loctite...
Offline Betty
« Reply #8 on: May 09, 2011, 11:46 PM »
My son had an oddy evo 2 on it for a couple of sessions, he complained about it coming loose... after i'd drilled/tapped it for gyro tabs!
Deffo needs countersunk bolts, you'd think they'd at least supply some washers that would do the job
With wobbly arms you can bet i've got the noisiest brake in the park...  ;D
Offline fugazi
« Reply #9 on: May 10, 2011, 09:11 AM »
I've never had any luck with brakemounts on S&M's! welded on the pish on Dirtbikes, wobbly & in the wrong place on My Blackbike V2 & now this  :LolLolLolLol:
Still love 'em though  :4_17_5:
Offline Betty
« Reply #10 on: May 10, 2011, 11:40 PM »
Rode it tonight and the brake works fine despite being a bit wobbly and hasn't come loose yet....  :daumenhoch:
Honks like a pack of demented geese though...  :D
Offline generallee
« Reply #11 on: May 12, 2011, 08:55 PM »
Mark, plumbers tape on the brake lugs before sliding the arms on will sort out that squeak!
steve
Offline kev-s
« Reply #12 on: May 12, 2011, 09:15 PM »
all brakes on s&m frames seem to wobble on the mounts, my laf, blackbike and 1st yellow dirtbike did this
i think this is why my last dirtbike cracked on the seatstay brake mounts, too many rocket tyre tap barspins, landing on the back wheel with your feet on the pegs pushes the brake arms outwards pulling the mount away from the frame where as chainstay mounts would make the brake arms push down onto the mounts
just waitng for mine to crack again (i cant stop doing rocket tyre tap barspins lol)
next frame will have chainstay mounts :daumenhoch: :daumenhoch: :daumenhoch:
Offline Betty
« Reply #13 on: May 12, 2011, 09:16 PM »
steve
Cool idea, i'll give that a try...  :daumenhoch:
Offline Betty
« Reply #14 on: May 12, 2011, 09:24 PM »
Just normal tyre taps for me...  :D
It does have me thinking how strong can these removable brake mounts be, they can't be as strong as welded on mounts
I've a mate that's broke welded mounts on 2 LTF frames landing whip airs with the brake on
