975755
TattooedYorkie
September 21, 2024, 04:04 AM
MONGOOSE SKYWAY HELP!!!
Topic: MONGOOSE SKYWAY HELP!!! (Read 1166 times)
ozzie_owl
May 15, 2006, 03:42 PM »
I've got a Mongoose California and i have bought a pair of blue Mongoose Skyways. I have replaced the axels in the Skyways and come to mount them on the bike but they won't. I looks like there is a nut too many?? Anyone come across this before?
I will post pics if that helps.
Lee.
ozzie_owl
Re: MONGOOSE SKYWAY HELP!!!
May 15, 2006, 05:12 PM »
gmac
May 15, 2006, 05:18 PM »
Just take the middle nut off. Maybe it was used as a spacer on the last bike the wheel was mounted on
ozzie_owl
May 15, 2006, 05:24 PM »
The big nut near the dropout? If so I tried that and the axel seemed lose then? Will it be ok when it's mounted and tightened up do you think??
BrianP
Cherry Picker
May 15, 2006, 05:27 PM »
is that a coupla washers between the conenut & locknut?
should be able to do away with these.
Bp.
ozzie_owl
May 15, 2006, 05:34 PM »
Theres the cone nut, bolt, washer, bolt at each side. Still doesn't look like it will fit even without the washers.
BrianP
Cherry Picker
May 15, 2006, 05:53 PM »
is the thin nut closest to the hub part of the cone nut or a separate nut?
if it's a separate nut, then you can do away with the outer locknut and washer (to the inside of the dropout) since the innermost thin nut will be locking against the cone.
all u need to have on each side of the hub is:
the ball bearings
cone
locknut
dropout
washer
wheelnut
any help?
Bp
anything else is just eating up space.
Moose
540 Air
May 15, 2006, 06:08 PM »
The washers are the only thing you can remove from there. Do that and then try flexing the drop-outs open and squeezing them in.
ozzie_owl
May 16, 2006, 01:59 PM »
Thanks for all your help guys, i'll try and fit them this evening.
May 16, 2006, 02:01 PM »
flex the rear end apart to get them in
its normal to do that
ozzie_owl
May 16, 2006, 02:12 PM »
I think the rear might be ok, it's the front i'm having trouble with. Want to see what it looks like before fitting them both.
Where did you get the blue Mongoose padset (the set you don't see very often) you had on the which pad thread?
Lee.
Reply #11 on:
May 16, 2006, 02:13 PM »
flex the fork legs apart then
again, that is normal. so long as its just a little bit.
ozzie_owl
Reply #12 on:
May 16, 2006, 02:19 PM »
Just tried, if i get one side in the other is out by the full with of the outer bolt (approx 7mm) and it doesn't seem to want to flax that much or i don't want to try and flex it that much. Without the washers it should fly in.
Reply #13 on:
May 16, 2006, 02:21 PM »
shit yeh if its that far astray then sack the washers
not sure what the washers are doing in there anyway!
ozzie_owl
Reply #14 on:
May 16, 2006, 02:23 PM »
Do they go at the other side of the dropouts or in the bin.
Padset?
Coastvl
Reply #15 on:
May 17, 2006, 05:40 AM »
Someone has put the washer in the wrong spot. It should go on the outside of the dropouts, then the axlenut. I've had to stretch all my forks out to fit Tuffs. Completely normal. Like me.
stuntmaster
540 Air
Reply #16 on:
May 17, 2006, 07:13 AM »
also those locknut`s are bigger than normal ones i seen ,not that there a problem but that what push the threads further out
no1stuntmaster on instagram
