975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 01:40 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Supergoose Needing A Seat Post Shim
Author Topic: Supergoose Needing A Seat Post Shim  (Read 1012 times)
« on: May 03, 2011, 08:37 AM »
Alright Fella's, just assembling my Supergoose 3 after a claen up/semi-resto. I've bought a MX hinged seat clamp from porkchop and I get get it nipped up tight enought to stop the seat post from turning a bit.
I'm thinking a shim would be the way to go to get a solid, tight fit, any ideas what size I would need to get??
Cheers Dan.
Re: Supergoose Needing A Seat Post Shim
« Reply #1 on: May 03, 2011, 08:56 AM »
The use of a coke can is the normal solution Dan. A pair of scissors will cut it up nicely or put a post up for an Elina seat post shim.  :daumenhoch:
« Reply #2 on: May 03, 2011, 09:49 AM »
Cheers Brett, i'll try the coke can, that's all it will need to be fair.
« Reply #3 on: May 03, 2011, 11:55 AM »
you have most likely sent a man to his own death  :shocked: any one knows that if you cut into a coke can, it will have it's revenge and cut him back - he will lay bleeding on the floor for hours and not be able to cry out for help  :shocked: :shocked:  why not tell him to run with scissors  ::) and kill him qiuckly !
« Reply #4 on: May 03, 2011, 01:01 PM »
Don't despair B, i'm gonna get the Mrs to do it.
dj_benice
« Reply #5 on: May 03, 2011, 02:47 PM »
Run with scissors? That's my mates clothing company lol
http://rwsclothing.bigcartel.com/product/rwsc-madams-tee
Offline oldtired
  • Dirty Old Man
« Reply #6 on: May 03, 2011, 09:19 PM »
cant beat shimming up a pole , works like charm been at it for years ,  moved on from coke cans now though being a bit older , trouble is, and i've said this before , you have to try 10 or 12 tins before getting the right one , thing is after that your realy not bothered if your seat spins round, as is not going as fast as the walls  :LolLolLolLol:
