975833 Posts in 138948 Topics by 6376 Members - Latest Member: The Carrot Cruncher January 07, 2025, 09:32 PM
RADBMX.CO.UK  |  New School BMX 2004 - Now  |  New School Park, Street & Dirt  |  Gyro Brake Set Up
Author Topic: Gyro Brake Set Up  (Read 1580 times)
Offline Peter J
  • I have issues
Gyro Brake Set Up
« on: April 22, 2011, 03:24 PM »
Can anyone tell what parts I need to set up a gyro brake on a N/S Bike.
I've got the "removable tabs" but need the list for the rest. I also want to run a London Mod and a double cable from the lever but do I need
This: http://www.odysseybmx.com/catalog/braking/monolever/
Or this: http://www.odysseybmx.com/catalog/braking/m2-lever/ Lever to run a Twin Cable
Can someone please help I've spent the last hour trying to work it out........... :uglystupid2: also I dont have a stem with any tabs on  :-\ so will I need a plate thingy  ??? also do
Also what FOOK are these for..... http://cgi.ebay.co.uk/Odyssey-BMX-Cable-Knarps-Cable-Ends-Pack-2-/220769649410?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item3366e58302
So COMPLETE Parts list please
Offline Gary72
Re: Gyro Brake Set Up
« Reply #1 on: April 22, 2011, 03:39 PM »
I've got to go and do some DIY, But I might be able to help you with some parts. I've got a few Modulever cables, a London mod thingy and might have a modulever aswell somewhere. If I dont reply later send me a PM to remind me. :)
Offline kev-s
« Reply #2 on: April 22, 2011, 05:37 PM »
you need a m2 lever http://www.customriders.com/prodshow.asp?prodid=7948&cat=27&parent=1001&sid=3
a gyro plate (make sure its a 1&1/8th not a old 1in one) ebay is your best bet if no one on here has one
dual lower cables http://www.customriders.com/prodshow.asp?prodid=7869&cat=14&parent=1001&sid=3
and a london mod
remember to oil all cables before fitting to get them working there best and just take your time setting it up and it will work just as good if not better than a straight cable
the knarps are basicly brake cable barrell ends, so if u have a cable with no barrell end you just fit those instead, when u fit the dual lower cable you will use these to anchor the cable into the brake arms
« Last Edit: April 22, 2011, 05:42 PM by kev s »
Offline Peter J
  • I have issues
« Reply #3 on: April 22, 2011, 05:52 PM »
Kev,
That M2 says it comes with "replacement bushes so when they wear you can replace them"
Why do they wear out  ???
Offline Peter J
  • I have issues
« Reply #4 on: April 22, 2011, 05:54 PM »
Also
I think I'm right in saying that the cable ends that go into the gyro plate need to be the small "bobble" type ones as apose to the barrel shaped ones  ???
Offline kev-s
« Reply #5 on: April 22, 2011, 07:03 PM »
no idea why they wear out, mine havent yet and its about 6 months old
yes the dual cable needs bobble ends not barrell ends, the one in the link has bobble ends
odyessy also do cables with a barrell on one end and a bobble on the other so if ur using it as a straight cable u cut off the bobble but if u wanna use it as part of a lower dual cable then u cut off the barrell
« Reply #6 on: April 22, 2011, 07:34 PM »
Pete, you're not a good enough rider to worry about a gyro :LolLolLolLol:
Offline Peter J
  • I have issues
« Reply #7 on: April 22, 2011, 08:04 PM »
Spen its so when I fall off I dont spend hours trying to un tangle the brake cable.......... :-[
............thats if I ever ride it  :2funny:
