975808 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 27, 2024, 01:34 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Polishing built wheels
Author Topic: Polishing built wheels  (Read 1407 times)
« on: April 21, 2011, 10:16 PM »
its a bitch to do so I never do it very well... but I'm always open to being shown the light.
Any tips on how to polish the hub / spokes / rims of a built allow wheel gratefully received  :smitten:
I've got a Peregrine 48 HP to sort out  8)
Offline john4130
Re: Polishing built wheels
« Reply #1 on: April 22, 2011, 12:38 AM »
the first thing you should do is remove the spokes, it'll save you half the time rather than trying to do it when built.  >:D
« Reply #2 on: April 22, 2011, 01:03 AM »
You retard Ed.
Like John said, remove the spokes and read a thread about re-lacing them :knuppel2: :daumenhoch: :LolLolLolLol:
Offline Munnyella
« Reply #3 on: April 22, 2011, 08:20 AM »
its dead easy Ed, if you take your time, even I can do it!!!
« Reply #4 on: April 22, 2011, 09:03 AM »
Got no interest in taking them apart HENCE THE THREAD  ::)  ;D
Can't be bothered with the down time of pulling spokes out so I was after tips on cleaning BUILT wheels  ^"^
Offline Betty
« Reply #5 on: April 22, 2011, 09:10 AM »
Ed i've tried it and gave up and took em apart, way easier...  :daumenhoch:
2 minutes turkish...
Offline oldtired
  • Dirty Old Man
« Reply #6 on: April 22, 2011, 09:34 AM »
spokes can be rubbed with 00 guage steel wool then finnished of with autosol the rims can be done on a buffer wheel along with the outside of the hub ,    its a real pain doing the spokes this way though ,    you will have to do the inside of the hub and between the spokes on the rim by hand or use a Dremmel type tool with a buffer wheel on it , i've done 1 36 spoke wheel this way once , never again ,   :uglystupid2: :uglystupid2:   to much fookin about and it will be twice as hard with a 48 ,   as everyone says easyest thing is strip it,  takes a couple of hours to strip polish and rebuild a wheel , if its a show bike job done, if its a rider just need to get it trued and tightened up at lbs if you cant do it yourself,  you'll get a better finnish stripping all the parts too
« Reply #7 on: April 22, 2011, 02:18 PM »
thanks for the replys gents... fook it then they can stay as they are  ;D
« Reply #8 on: April 22, 2011, 02:34 PM »
Better like that   :daumenhoch:
« Reply #9 on: April 22, 2011, 02:56 PM »
use your bollocks Ed >:D you can wrap em around the spokes no probs
Offline gary4130
« Reply #10 on: April 23, 2011, 04:11 PM »
ed you could tape the spokes together ,then undo the all the nipples -then when you put wheel back together at least the all the spokes are still built into the hub   :daumenhoch:
done this myself +it saves a bit of time
« Reply #11 on: April 23, 2011, 05:15 PM »
Me too Ed, but you still need someone with skill to do the final tension :daumenhoch:
