975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 01:07 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Pitbull positions
Author Topic: Pitbull positions  (Read 964 times)
Pitbull positions
« on: April 13, 2011, 12:18 PM »
Before I start cock-a-doodle-doing about with it does anyone know if I can run a Oddy Pitbull 'under' the brake bridge?
cheers...
« Last Edit: April 13, 2011, 12:23 PM by ED209ยบ »
Re: Pitbull positions
« Reply #1 on: April 13, 2011, 12:28 PM »
not to sure you can Edwardo, the only other way (and by far the neatest) is to run them on the chainstays when they have a hole through the seat tube (like my assassin) but those Haro's came with them like that mate.  messy aint they
« Last Edit: April 13, 2011, 12:31 PM by pickle »
« Reply #2 on: April 13, 2011, 12:33 PM »
you could always ditch the black cable holder thing and use an Oddy Pozi stop seat clamp instead?  might make it look a bit better and allow you to run it underneath?
Offline boofy44
« Reply #3 on: April 13, 2011, 02:14 PM »
i've got one underneath on my dirtbike.bit of a tight fit but it works fine.
« Reply #4 on: April 13, 2011, 02:32 PM »
no reason why not, but you may do well to use a linear slick cable to allow tight bend round the seat tube so won't impead inner cable
i dont think a pozi stop would work as i'd assume the angle to cam would be way off
« Last Edit: April 13, 2011, 02:34 PM by OrgasmDonor »
« Reply #5 on: April 13, 2011, 02:35 PM »
cool - I'll give it a go then - I've got a new lower Odyssey cable off Stodge and it can't be any more tight on the turns than it already is!
will have a play tonight  :daumenhoch:
« Reply #6 on: April 13, 2011, 05:46 PM »
Just out of interest ed, what's wrong with it the way it is? Seemed to work real well on Saturday.
« Reply #7 on: April 13, 2011, 06:01 PM »
gets in the way of my Craig Campbell style Framestand fakie airs...
duh! isnt that obvious Rob  ;)
« Reply #8 on: April 13, 2011, 06:05 PM »
of course.....what was i thinking  ::)
« Reply #9 on: April 14, 2011, 07:59 AM »
So how did it go Ed?  did it work okay?
