975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 03:06 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  bottom bracket confusion... help :)
Author Topic: bottom bracket confusion... help :)  (Read 6789 times)
mattuk
Re: bottom bracket confusion... help :)
« Reply #25 on: April 15, 2011, 10:38 AM »
if it is one on them where the hell do i get one from :O  just look ey has nothing apart from importing from amercia at around £35+
if thats case im just selling the haro cranks and buying a new chrome crankset that comes with BB already on
now ive ordered a 22m BB  that should be here today/tomorrow.... would the original bearing that came with the axle (guessing now theri 20mm)  would they fit inside the 22mm BB's cups ?    cause that could work?
they never went in the other cups thats all even after sanding
HEYWOOD BMX
« Reply #26 on: April 15, 2011, 10:59 AM »
 :) Gussett and D20 both do 20mm BBs (D20 are cheaper) Alans and Custom Riders sell them.Wait until you get your new BB and see if it fits.Haro/Fusion did make cranks with 20mm axles for years... :daumenhoch:
Offline fugazi
« Reply #27 on: April 15, 2011, 11:30 AM »
You're having a right old time with this  :LolLolLolLol: as said they'll more than likely be 20mm then as i don't think Fusion did 22mm. Gusset and Fishbone also used a 20mm b/b for years if that helps  :daumenhoch:
mattuk
« Reply #28 on: April 15, 2011, 11:48 AM »
gotta try and see the funny side i guess....  im hoping i can get the bearing that came with the crank and definitely fit it will pop into the new bearing cups
i'll get searching for a 20mm bottom bracket just in case
although im seriously thinking to ebay the haro fusion crank and invest in a nice second hand profile one or something and pay the extra $$$
anyone got one for sale or even just a nice chrome 3 piece WITH A BB THAT FITS    :P
« Reply #29 on: April 19, 2011, 05:51 PM »
Just to iron this out a bit for you fellas...
A proper US BB is not metric. The axle is actually 3/4"   (19.05mm), so near as dammit and causes no problems. However, some companies have everything made in Taiwan and/or China (all metric), and have taken over the years to using some oddball sizes for things.
Stick to what you know, traditional stuff, and you'll be fine. A good ole US BB will suit Profiles or Flights no worries. That DiamondBack BB is fine for the job.
