975755
TattooedYorkie
September 25, 2024, 06:23 AM
extending bars
Topic: extending bars (Read 1370 times)
motomagII
extending bars
April 06, 2011, 08:38 PM »
is there any easy way extending bar width without welding please guys need inch or so on either end
waza04
Re: extending bars
April 06, 2011, 08:51 PM »
you could sleave them, dont really seem worth it though for an inch.
Last Edit: April 06, 2011, 08:52 PM by waza04
stfc
Rockwalk
Re: extending bars
April 06, 2011, 08:52 PM »
Bluetack??
welding surely would be the only way if your gonna ride it , If its for a show bike doweled wood machined on one end to slide inside the bars??
motomagII
Re: extending bars
April 06, 2011, 08:55 PM »
an inch makes a massive difference either side the bars are 24 wide as new.i ride bars at 28 but wanna try set at 26 as 28 is bit too wide for me
wanna get em rideablke at 26 see if they are okay if not then go for 27 etc etc
waza04
Re: extending bars
April 06, 2011, 08:58 PM »
make a couple of sleeves then mate, and add a little at a time till they feel right...... then i think you only safe bet would be to put the sleeve in and weld them up. grips would cover up any welds.
HUTCHMAN
540 Air
Re: extending bars
April 06, 2011, 09:02 PM »
i've thought of one way of doing it where it will be completely removable but can't really explain it.would have to draw it and put it on here,but my daughters away at the moment(she'd know the photo bucket bit).give me a day or two.
monkian
Re: extending bars
April 06, 2011, 09:03 PM »
Could they be threaded like a little euro BB
HUTCHMAN
540 Air
Re: extending bars
April 06, 2011, 09:11 PM »
what i was thinking of has the inner end like a quill stem,with the bar extension part being the same diameter of the ext dia of the bars with an allen bolt (like the stem bolt) to tighten things up.(hope that makes sense)
Dannywhac
BMX Nerd
return of the whac
Re: extending bars
April 06, 2011, 09:25 PM »
Could you get some wedge type bar ends, and only pop 'em in halfway (and tighten em), then use some leccy tape to build up to the same thickness as the bars. Not advisable for any lengthy rides, but will give you the feel of the bars at different widths.
Last Edit: April 06, 2011, 10:13 PM by dannywhac
"Listen. I don't care what you say. Chlamydia is a soup."
(Phelps, L. 2000)
James Nada
Look Back
Re: extending bars
April 06, 2011, 09:51 PM »
There is a product for MX bikes which does this - they are kinda bolt on extensions that you'd cover up with grips. I think Renthal make some (probably won't be cheap though).
Betty
900 Air
Re: extending bars
April 06, 2011, 11:32 PM »
Cut off broom handle in the grips....
Karl Sanderson raced at MK10 with em...
2 minutes turkish...
extending bars
