975800 Posts in 138943 Topics by 6362 Members - Latest Member: Bmxflex November 18, 2024, 09:51 AM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  CHAIN RING,FREEWHEEL-GEARING QUESTION ??
Author Topic: CHAIN RING,FREEWHEEL-GEARING QUESTION ??  (Read 419 times)
Offline HARORIDER
« on: April 05, 2011, 04:09 PM »
ok most people have 44 front 16 back but is 43 front 17 back the same  :-\ and does 43 front 16 back make much of a difference :-\
Offline kuwahero
    • Western Titans
Re: CHAIN RING,FREEWHEEL-GEARING QUESTION ??
« Reply #1 on: April 05, 2011, 04:14 PM »
44:16 will have gear ratio of 55.0
43:17 will be 50.6 and 43:16 will be 53.8 so quite a big drop if your looking for something slightly easier than 44:16
xGoose
« Reply #2 on: April 05, 2011, 04:21 PM »
44 16 is kind of the industry standard optimal gearing ratio but it also depends on tire size as well. 43 17 is not the same though and would be way easier to crank and quicker to spin out. If you wanted to use 17 on the back and get the same result as 44 16, youd need 47(ish) on the front. 43 16 would not make too much difference.
As a general rule Ive heard you can say that 1 tooth on the back is the same as 2.5 / 3 on the front and making cogs bigger on the front gives taller (harder) gearing but making bigger cogs on the back gives easier gearing.
 :P
Hope that helps!
Offline aerostylie
« Reply #3 on: April 05, 2011, 05:55 PM »
does crank arm length matter as well cos of the different sizes?
ps once ran 41 18 gearing, doh :crazy2:
« Last Edit: April 05, 2011, 05:59 PM by aerostylie »
Vans Style
« Reply #4 on: April 06, 2011, 10:52 AM »
thats the stuff of MK 07 legend  :LolLolLolLol:  :daumenhoch:
41 : 15 is between 44 and 43 : 16,
longer n shorter cranks with only affect the amount of effort required and not the speed (plus its usually only 5mm so its more psychological than owt else)
moley
« Reply #5 on: April 07, 2011, 03:39 PM »
I raced Bradford (Old Track before the revamp) using 47t/16t a  few years ago!!
Its a leg builder I tell thee!!  :LolLolLolLol:
« Reply #6 on: April 07, 2011, 05:22 PM »
mongoose shipped the team goose and supergoose with a 14T shimano cassette hub and 39T chainring which effectively gives roughly the same gearing as 44/16.
Personally I use 44/16 on my cali rider but switched to 43/16 on my supergoose that I use for wobbling round coppull cos I'm slow and shit and needed slightly easier pedalling up the mountainous coppull track  :-[ :D
