975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 05:25 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  QUICK BRAKE QUESTION, help asap!
Author Topic: QUICK BRAKE QUESTION, help asap!  (Read 609 times)
d14vd_h
« on: May 11, 2006, 12:26 AM »
hey guys im hopefully after all thse weeks taking my team burner to be powdercoated tomoro
ive stripped it all but the last thing i cant do is remove the cable from the caliper arm its attached to!!
can anyone give me a step by step
pictures for illustration would be immense
thanks guys!
Re: QUICK BRAKE QUESTION, help asap!
« Reply #1 on: May 11, 2006, 09:06 AM »
the cable goes through the adjuster and is then clamped into the other caliper arm. undo the 8mm nut to release the clamp
if the cable's outer sleeve is stuck in the adjuster, give it a good yank. if the clamp is wedged holding the cable in place, press it back through using some pliers, or even a few taps with a hammer
« Reply #2 on: May 11, 2006, 10:22 AM »
dont forget the salt.
« Reply #3 on: May 11, 2006, 10:33 AM »
