976205 Posts in 138988 Topics by 6419 Members - Latest Member: BMXBoyBrookie March 24, 2026, 02:24 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Crank Question
Author Topic: Crank Question  (Read 1638 times)
76
Crank Question
« on: March 20, 2011, 09:35 PM »
Hi,
I've got a Redline one piece crank, I also have a bottom bracket.  The bottom brackets doesn't fit over the arms of the crank at the pedal ends.
Am I doing something wrong? I kinda can't see I am, so the questions is, do I need a new crank or bb and how do I know that they will match?
Thanks
Re: Crank Question
« Reply #1 on: March 20, 2011, 09:52 PM »
pictures please
Re: Crank Question
« Reply #2 on: March 20, 2011, 10:10 PM »
Put the chain ring or spider on first, then a big nut with a bearing cone on it. then a bearing race, make sure it fits snug. Then grease the bearing cups, bearings etc. Slide the arm through the bottom bracket, make sure its the right way round.
Then put the next set of bearings in, followed by another big nut with a bearing race, finally the lock washer and lock nut. Hand tighten until theres no movement, then undo half a turn, then tighten the lock nut up.  :daumenhoch:
oldskooldayz
Re: Crank Question
« Reply #3 on: March 21, 2011, 09:01 AM »
Hi,
Thanks
Take the pedals off first  :2funny:  :LolLolLolLol:
Offline rooski
  • Mons Veneris
Re: Crank Question
« Reply #4 on: March 21, 2011, 05:37 PM »
is it a sealed bb ???
76
Re: Crank Question
« Reply #5 on: March 21, 2011, 05:51 PM »
Right, give me a couple of hours, let me get the little one in bed and I'll take some pics!!!
