975810 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 10:20 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  replacing shimano dx pedal pins
Author Topic: replacing shimano dx pedal pins  (Read 1491 times)
firebird4130
« on: March 12, 2011, 07:10 PM »
Anyone know a good way of doing this? How to remove old ones,Where to get new ones from etc
Cheers  :daumenhoch:
Fraz
Chinadog
Re: replacing shimano dx pedal pins
« Reply #1 on: March 12, 2011, 09:20 PM »
If they won't pull out then you have to drill them out.
start off with the smallest drill bit you have working up to one thats slightly smaller than the pin. once you've done that they should come out with a bit of wiggling/twisting.
It sounds easyer than it is unless you have a pillar drill, but it is possible with a normal drill and top quality drill bits if you take your time.
I couldn't find replacement pins for sale anywhere but found vp dx style pedals (vp555) have the same size pins fitted and cost about £6-7 on ebay so i got some of those and cut the pedals off the pins if you know what i mean. ;)
« Reply #2 on: March 13, 2011, 12:56 AM »
pictures people, pictures  :coolsmiley:
« Reply #3 on: March 13, 2011, 01:01 PM »
f you use the search function you should find a Steve P post on how to replace the pins and a suggestion on what to use in place  :daumenhoch:
firebird4130
« Reply #4 on: March 13, 2011, 01:25 PM »
awesome, will give that a go,
Cheers  :daumenhoch:
