975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 05:50 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  dyeing a padset
Author Topic: dyeing a padset  (Read 868 times)
Offline john4130
dyeing a padset
« on: March 03, 2011, 04:55 PM »
i wanna dye a yellow nylon padset to black, will this ruin the print on it. the print is blue white and red, also can the foam be dyed too. cheers
Re: dyeing a padset
« Reply #1 on: March 03, 2011, 06:20 PM »
Hi mate - I dyed a faded black pad set back to black
the pad set on one side had turn faded brown
the print was white writing
i only dyed the covers not the pads
I used dylon mp dyes - one tin  - boiling water in a plastic tub/washing up bowl, that would hold hot water
I left it for about half an hour to soak with a stir once in a while
The print turn grey straight away and soaked the colour up - the brown turned back to black and a solid black
I didn't mind them turning grey as they matched the grips
you can turn pad sets back to the right colour BUT it will turn print colours around and may not be what you are looking for - then it will have to be a repro set
you can try it and see if it works - nothing to loose unless it's too valuable to change
hope this helps - cheers B  ;)
Offline john4130
Re: dyeing a padset
« Reply #2 on: March 04, 2011, 01:33 AM »
cheers mate, think i'll give it a go. yellow just don't look right but i tried a plain black set on my build and it looked better. gonna scan the print first just incase it goes tits up. unless someone wants to swap a set of original yellow ammaco pads for black one's. i won't hold my breath tho
