975755
TattooedYorkie
September 21, 2024, 09:07 PM
Paint over powder ?
Topic: Paint over powder ? (Read 859 times)
SteveG
Curb Endo
Paint over powder ?
February 13, 2011, 09:10 PM »
My landing gear forks were in a bit of a state so I thought black powder would be a good idea. Not so sure now and was wondering if it's possible to paint over the powder with anything. They had really bad rust pitting on them so wet spraying may have been a better option.
Could the powder be flatted and then overcoated ?
Del
Look Back
Re-living my youth!
Re: Paint over powder ?
February 14, 2011, 08:49 AM »
yes it can, done it myself with a few frames... no problems at all.
SteveG
Curb Endo
February 14, 2011, 09:40 AM »
Just worried about possible reactions. What did you use ?
The forks in question were standing gears I cut the stands off of. They looked like they had been left in a bucket of water for about 15 years when I got them. I filed the worst of the rust off and then got them blasted but the black powder finish is more like plastic coating and is a bit orangepeeled.
I fancy baby blue now though as there is a bit too much black on the bike
Last Edit: February 14, 2011, 06:05 PM by SteveG
Swivel
Berm Worm
Ah feck it, go on then...
February 14, 2011, 09:45 AM »
I've had it done before no problem
SteveG
Curb Endo
February 14, 2011, 06:09 PM »
Just edited my post as I mixed Del up with Dan
Thanks for the reply Del and Swivel what paint did you use. Will almost anything be ok I guess the powder is pretty much resistant to everything.
meticulous
Berm Worm
February 14, 2011, 07:28 PM »
i wet spray over powder all the time and never had a problem, i would go as far to say the powder is the perfect underrcoat coat to work from, all you need to do is flat down the powder with 400 wet n dry for the paint to key too....
R.I.P O.M. Far short of the finish line...
SteveG
Curb Endo
February 14, 2011, 08:36 PM »
Thanks for the advice, might give it a go.
I suppose the other option if I stay black is to flat the powder off and try and re-polish it. Never tried that either.
superbikedan
BMX Legend
900 Air
February 14, 2011, 08:54 PM »
hi steve believe it or not but the solvents in wet spray soften powder witch then
make it a good key and the paint sticks well, all i would do is flat the powder down as
much as you can and try not to flat back to raw metal, just work on the pitted
areas and a light flat over the rest and they should come out good
SteveG
Curb Endo
February 14, 2011, 09:43 PM »
Hi thanks for the reply Dan.
I've messed about with cellulose on cars and did a bit of paint testing at work but know zero about powder coating.
I've been thinking about changing the colour of the forks for a while, time to do a quick photoshop (more like a few hours) and see what it looks like.
meticulous
Berm Worm
February 14, 2011, 09:44 PM »
like dan says, the solvents in the paint seem to soak in the powder, dont bother polishing the powder, it the same colour all the way through and wont get any shinier...
Paint over powder ?
