975810 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 10:42 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  tight head set
Author Topic: tight head set  (Read 777 times)
tight head set
« on: January 29, 2011, 03:05 PM »
got an old frame and forks cant get top nut off a tange head set , its tight as fook  >:( drowned it in wd 40 but try as i might it wont budge . not bothered to much about head set as im gona replace it but i got to get it off first ... HELP.
Re: tight head set
« Reply #1 on: January 29, 2011, 03:42 PM »
Use an angle grinder and take your time. Grind two of the side ( opposite) until they get thin then back to a spanner and it should snap.  Just gind slowly once you are through the worst of the metal you could swap to a course file so as no to damage the forks. :daumenhoch:
Re: tight head set
« Reply #2 on: January 29, 2011, 03:43 PM »
Try hitting it with a hammer to shock the corrosion into breaking
Re: tight head set
« Reply #3 on: January 29, 2011, 03:45 PM »
put a wheel into the forks and stand with the wheel between your knees, use a large pair of adjustables (not a swan neck) or a pair of Stilsons and undo it  :daumenhoch:
waza04
Re: tight head set
« Reply #4 on: January 29, 2011, 03:47 PM »
there's no substitute for big amount of leverage...................  :crazy2:
ozone
Re: tight head set
« Reply #5 on: January 29, 2011, 04:06 PM »
Nice muscle-top.   :-*
Re: tight head set
« Reply #6 on: January 29, 2011, 05:20 PM »
Heat aswell get a blow torch on it  :daumenhoch:
Offline 58 delray
Re: tight head set
« Reply #7 on: January 29, 2011, 05:23 PM »
you could try a nut splitter, available from decent motor factors  :daumenhoch:
Re: tight head set
« Reply #8 on: January 30, 2011, 10:23 AM »
just smash it up man...ffs
Re: tight head set
« Reply #9 on: January 30, 2011, 09:38 PM »
thanks for all the advice lads. in the end wheel on, heat on gently tighten, well tighten even more. than eventually got it off  :daumenhoch: so some TW Airlines T maid had used some kind of lock tight /metal glue or something  :uglystupid2: anyway its off now and threads on the forks are ok
« Last Edit: January 30, 2011, 09:50 PM by Badbaldie »
Re: tight head set
« Reply #10 on: January 30, 2011, 09:47 PM »
should have smashed it
Re: tight head set
« Reply #11 on: January 30, 2011, 09:47 PM »
thanks for all the advice lads. in the end wheel on, heat on gently tighten, well tighten even more. than eventually got it off  :daumenhoch: so some TW Airlines T maid had used some king of lock tight /metal glue or something  :uglystupid2: anyway its off now and threads on the forks are ok
Nice 1 :daumenhoch:
Re: tight head set
« Reply #12 on: January 31, 2011, 10:57 AM »
 :4_17_5:
