975805 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 10:41 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  CLEANING MOTOMAGS.
Author Topic: CLEANING MOTOMAGS.  (Read 959 times)
ozzie_owl
CLEANING MOTOMAGS.
« on: May 04, 2006, 02:36 PM »
Whats the best way to clean a pair of Motomags?
Cheers Lee.
motomagII
Re: CLEANING MOTOMAGS.
« Reply #1 on: May 04, 2006, 06:12 PM »
they are cast alloy i believe .this means to me wet and dry from rough to mega mega couse then loads a polishing the more you polish the more they shine .takes long time though i spent 4 hours on  mongoose pro class rim .
ozzie_owl
« Reply #2 on: May 04, 2006, 06:30 PM »
Wet/dry sandpaper, the kind you get from B&Q? If so won't that damage the finish at all?
Lee.
Offline Steve P
« Reply #3 on: May 04, 2006, 06:48 PM »
I restored a set a few years back using car alloy wheel cleaner . . . brush it on, leave it about 10 mins then wash it off
It worked really well and they polished up a treat without the need to use abrasives
Steve  :daumenhoch:
ozzie_owl
« Reply #4 on: May 04, 2006, 06:58 PM »
Thanks for that Steve, any particular make of alloy cleaner and polish?
Lee.
Offline Steve P
« Reply #5 on: May 04, 2006, 07:07 PM »
Steve  :daumenhoch:
Any branded alloy wheel cleaner will do the job Lee . . . Simoniz, Autoglym or Wizard Wheels but not the cheap aerosol foam . . . that stuff is cr@p
Try your local car shop or Halfords
Hope this helps
Steve  :daumenhoch:
« Last Edit: May 04, 2006, 07:22 PM by Minihaha »
Bren Gunn
« Reply #6 on: May 04, 2006, 07:18 PM »
What he said ^^^^^^^
Don't sand them and don't over polish them, nice and clean is what you want :daumenhoch:
