975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 02:14 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Simple one if you know - Profile crank washer size?
Author Topic: Simple one if you know - Profile crank washer size?  (Read 472 times)
Rooonga
« on: January 19, 2011, 09:16 PM »
Hi peeps,
Like I say easy if you know!
I need a couple of washers for a set of profile racing cranks, and wondered what the size is, and also if anyone knew where I might get a couple from?
The ones I mean are the ones that go under the bolt that tightens the crank arms, not the spacers under the cranks.
Cheers!
Offline Gary72
Re: Simple one if you know - Profile crank washer size?
« Reply #1 on: January 19, 2011, 09:23 PM »
Buy some flush ones you tight git :daumenhoch:
