975753
TattooedYorkie
September 12, 2024, 06:51 PM
what does POTTS MOD mean
Topic: what does POTTS MOD mean (Read 4902 times)
d14vd_h
May 04, 2006, 12:18 AM »
building up a raleigh styler and want to make it as freestyle orientated as possible so
im planning on sticking on a set of diacompe fs 880 - 900 brakes
however ive seen a few described as potts mod
excuse my ignorance but what does this mean?
Frosty
Re: what does POTTS MOD mean
May 04, 2006, 12:24 AM »
That'll be the hollow stem bolt for routing the brake cable
d14vd_h
May 04, 2006, 12:25 AM »
ah ok so is it designed to be used with a gyro??
and should the forks have a specific bit for routing the wire up the back of them like ive seen on some freestyle bikes
billstup
Team Owner
My life is Radbmx
Posts: I am a geek!!
May 04, 2006, 12:26 AM »
Potts mod is the hollow stem bolt that the brake cable goes through, so a front potts mod brake will be upsidedown so to speak where the brake linkedge is
May 04, 2006, 09:03 AM »
you dont necessarily need the cable guide on the fork. you can use a cable tie there
and you dont have to run a gyro either.
OrgasmDonor
Berm Worm
I got the sauce for beef butterflies
May 04, 2006, 04:08 PM »
it's a modification made by mr potts, silly
BrianP
Cherry Picker
May 04, 2006, 04:44 PM »
first developed by steve potts, mike "bmx action trick team" buff's brother.
adeshere
May 06, 2006, 10:08 PM »
The front brake is set up different to the rear brake.
Where the brake cable sleeve is held, this is on the bottom arm and the bolt that actually clamps the cable is on the top. (The rear brake is opposite ie the clamp bolt is on the bottom arm)
This is done so the cable can come from below the brake to allow clearance when the bars are turned so it does not hit the frame.
tricknuts
Cherry Picker
May 08, 2006, 02:22 AM »
When Neville potts from Newcastle went to fight the rockers on the seafront at brighton..
May 08, 2006, 02:23 AM »
lol
Stace
540 Air
May 13, 2006, 07:24 AM »
Gents,
Anyone got any links to this mod with pics?? I'm a bit thick
Ta
Stace
BrianP
Cherry Picker
Reply #11 on:
May 13, 2006, 10:20 PM »
this any use stace?
cable goes from lever, down through fork steerer tube, and outteh bottom, back up to the front brake.
Bp
greentoad
Reply #12 on:
May 13, 2006, 10:25 PM »
Hi
This may help.
http://www.radbmx.co.uk/forum/index.php'topic=11903.new;topicseen#new
J.
