975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 07:34 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  PK Ripper my first build
Author Topic: PK Ripper my first build  (Read 6000 times)
simo27
« on: January 03, 2011, 10:30 AM »
Hi all
The Ripper is coming along well, pictures will follow.  One question, it is a 1983 model, what brake should I put on?  I have some Mx 1000's ( I think) but I am saving them for another build.  Any advice very much appreciated :)
Chris
Re: PK Ripper my first build
« Reply #1 on: January 03, 2011, 10:55 AM »
if you dont want to use the mx1000 then try dc 890's or 1020,although a bit more basic looking they are still great brakes and proper old school,or try shimano tourney
they are still readily available from vertego and wont break the bank
« Reply #2 on: January 03, 2011, 10:59 AM »
Idealy mx1000 but as Markyp said all the others are acceptable and probably cheaper.  Now get the pictures up  :LolLolLolLol:
Offline WARDY
« Reply #3 on: January 03, 2011, 11:00 AM »
890 s reach  ???
trasher
« Reply #4 on: January 03, 2011, 11:00 AM »
I don't think anything under an mx1000 will reach
So mx1000 or 1020
I could be wrong though
Offline WARDY
« Reply #5 on: January 03, 2011, 11:01 AM »
1000s , 1020s and tourneys reach
Offline WARDY
« Reply #6 on: January 03, 2011, 11:11 AM »
its in mm aint it , from centre of spindle to bottom of lowest point brake pads can go , mx1000 are 100 mm ( take the end zero off) 900 90 mm and so on
« Reply #7 on: January 03, 2011, 11:23 AM »
 :daumenhoch: What Carl said  ;)
Are you sure its a 1983 Ripper, you can't identify the year/age of a Looptail Ripper from the serial number .
Only the fact that it is approx late 79 upto late 84
The only way you'll know what age it is is if you or mate  bought it at the shop originally  :daumenhoch:
simo27
« Reply #8 on: January 03, 2011, 11:34 AM »
Ta for that, whaen I bought it off ebay about 6 years ago (has taken that long to doing it) the seller had it from new and said it was 83, it is a looptail any way ;)
simo27
« Reply #9 on: January 03, 2011, 11:36 AM »
Thanks all , much appreciated, I have seen a Tourney on Vertego, will go for that I think, right wheres me camera?!!
sid1972
« Reply #10 on: January 03, 2011, 02:41 PM »
there's a blue and white build on here somewhere were 900's have been used and they do not reach.. :-\
so 890's are out...  :daumenhoch:
Rodgy1970
« Reply #11 on: January 03, 2011, 02:58 PM »
A tourney might also be too short, check this out first.
Offline john4130
« Reply #12 on: January 03, 2011, 03:06 PM »
don't use mx900s. i made that mistake and even with the wheel as far forward as it goes the brakes only half catch the rim. now changed to an mx1000 thanks to snav.
« Reply #13 on: January 03, 2011, 03:19 PM »
Nice chart Rodgy  , a  good reference :4_17_5: Good for Tech and resto sticky  :daumenhoch:
Like advised  earlier by Wardy , these have been tried and tested (MX1000 ,Tourney and 1020's )
Plus Cotty built up a looptail Ripper  this week with a Tourney  :daumenhoch:
« Last Edit: January 03, 2011, 05:35 PM by Hunterdubber »
simo27
« Reply #14 on: January 03, 2011, 05:29 PM »
Thats great that Rodgy, very helpful and a good read as well!
simo27
« Reply #15 on: January 03, 2011, 05:30 PM »
Wouldnt mind a MX1000 but think they may be a bit expensive!
Offline 58 delray
« Reply #16 on: January 03, 2011, 05:44 PM »
what colour you after?
simo27
« Reply #17 on: January 03, 2011, 05:51 PM »
The f&f are yellow and the rest is black with chrome cranks, so black, chrome or gold
« Reply #18 on: January 03, 2011, 05:59 PM »
early SE adverts show the loopy ripper with the caliper underneath the brake bridge so not so sure if this is how OM designed it, but for me i think 1020's look more at home on a loopy just because they are a bit more OLD school without the snobbery....    ;)
Rodgy1970
« Reply #19 on: January 03, 2011, 09:17 PM »
No probs  :)
Put up a wanted add for some DC 1020's, should be able to get some handy enough.
« Last Edit: January 03, 2011, 09:21 PM by rodgy »
Moza
« Reply #20 on: January 05, 2011, 10:12 AM »
Its hard to see on this picture but it does look like a Mx1000 ?????????
and in this picture they are fitted on the reverse and they aint MX1000's
« Last Edit: January 05, 2011, 10:17 AM by Moza »
simo27
« Reply #21 on: January 05, 2011, 07:33 PM »
Thanks Moza, think i remember this from an old BMX Action Bike! May try and fit it from underneath, see what happens!
