975755
TattooedYorkie
September 19, 2024, 09:33 AM
Headset for Aero Reflex
Topic: Headset for Aero Reflex (Read 815 times)
Superkav
May 01, 2006, 10:11 AM »
Tried a couple of cheap ones from Billys.co.uk but they seem a bit too big and I don't want to fook it up, what headset have you Reflex owners used??
sawzall
540 Air
Re: Headset for Aero Reflex
May 01, 2006, 10:16 AM »
on my daughters aero i used a diamond back one ,under £4 from halfuc*ks had no probs with it
Steve P
900 Air
May 01, 2006, 10:26 AM »
I used the Hatta MX100 alloy set on mine
The Tioga Beartrap and MX-600 will be OK too . . . contact Wolfy
Steve
Rombloke
Team Owner
My life is Radbmx
do one
May 01, 2006, 02:50 PM »
headsets are meant to be 'f' tight
Dave
haro, how do you do
retrogeezer
May 01, 2006, 10:33 PM »
did crack an Aero Reflex head tube putting in an alloy Hatta headset.....was using a proper install tool as well.
Steve P
900 Air
May 01, 2006, 11:44 PM »
I find the MX100 steel top race is always a swine to press in to any frame so I increase the starting taper on a bench grinder
Works every time
Steve
