975805 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 01:47 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  stupid question about inner tubes...
Author Topic: stupid question about inner tubes...  (Read 1200 times)
« on: December 12, 2010, 09:24 PM »
good evening radsters
I know I've already  asked some pretty n00b questions on here, but here's another one...
I'm getting some haro tyres for my bike fairly soon, as far as I know these run to a fairly high PSI.
Now do i need any particular kind of inner tubes to go with these, or are these things pretty much of a muchness?
Reason I ask is because I already got one (Kenda) free in the box when I ordered some other bits from alansbmx, wondered if I needed to get just one more of these or a pair of something else when the time comes
cheers
Bettyswallocks
Re: stupid question about inner tubes...
« Reply #1 on: December 12, 2010, 09:31 PM »
Your kenda tubes will be fine
You dont have to put whatever the manufacturers state as max pressures on the sidewalls in the tyres dude, just whatever feels best for you, around 70-80 psi is usually fine...  :daumenhoch:
Bettyswallocks
« Reply #2 on: December 12, 2010, 09:35 PM »
If you're running skyways i think the max pressure is about 45 psi above that the tyres can pop off the rims
Although i've run one on the front with 70 psi and not had any probs... soon took it off... flexibagoshite...  :D
« Reply #3 on: December 12, 2010, 09:45 PM »
I have run 70 psi on skyways with comp ST's  :D
Kenda toobs will be fine up to 100psi, its the tyre rating that matters  :daumenhoch:
Bettyswallocks
« Reply #4 on: December 12, 2010, 10:07 PM »
Go on dude.... get a pic of the fokker up....  :daumenhoch:
« Reply #5 on: December 12, 2010, 10:11 PM »
Go on then
Bettyswallocks
« Reply #6 on: December 12, 2010, 10:19 PM »
 :4_17_5:  :smitten:
How did such a beaut get snubbed as botm..... its a fix i tell thee....  :tickedoff:
« Reply #7 on: December 13, 2010, 10:16 AM »
thanks guys for the info - wasn't sure whether there'd be some kind of issue with the valves not coping (and yes I'm going to be running skyways too so will bear that in mind)
cheers
Al Wyn
« Reply #8 on: December 13, 2010, 10:47 AM »
For reference @ 3.16
« Reply #9 on: December 13, 2010, 04:03 PM »
Stuff the tyres full of grass like you used to when you had a puncture as a kid  :daumenhoch:
« Reply #10 on: December 13, 2010, 07:45 PM »
grass?  :LolLolLolLol:
what about discarded moustache hair?
« Reply #11 on: December 13, 2010, 11:21 PM »
You would need to wait a few years though :LolLolLolLol:
