VERDE THEORY 2011
Frame:
Chromoly main frame with heat-treated investment cast head tube and integrated Pivotal post, removable brake mounts, Japanese seamless tubing
Fork:
Chromoly steerer tube, tapered legs, integrated lower bearing race
Chainset:
100% heat-treated chromoly 3-piece, 170mm, 8-spline spindle
Chainrings:
25 tooth steel
Bottom Bracket:
Sealed mid BB, 19mm
Cassette:
9 tooth loose-ball driver with internal sealed bearing (semi-sealed)
Chain:
Taya 410, black
Pedals:
DUO Resilite
Front Brake:
Basic Caliper
Rear Brake:
Alloy U-brake
Brake Levers:
2-finger lever
Handlebars:
100% chromoly with 8.1" rise and 28" width
Stem:
Alloy front load, matte black
Headset:
Integrated, sealed
Grips:
DUO Cranmer flangeless with Odyssey Par Ends
Rims:
Cinema 777 double wall rear and single wall front, 36 hole
Front Hub:
loose-ball hub with 3/8" axle
Rear Hub:
9t 1 sealed bearing (semi-sealed) in the rear hub with 14mm axle
Front Tyre:
DUO Stunner 2.20"
Rear Tyre:
DUO Stunner 2.20"
Saddle:
Verde Pivotal
Seatpost:
integrated post
Accessories:
1 pair of pegs, 38mm, steel
Weight:
(in Kg): 10.50
(in lbs): 23.15
VERDE RADIA 2010
Model Year
2010
Frame
100% chromoly w/removable brake mounts, 20.5" top tube
Fork
Verde design, 100% chromoly, tapered legs
Handlebar
Verde design, chromoly , 8" rise, 10° back, 4° up
Stem
Verde design, front load
Grips
DUO Cranmer, flangeless (black)
Bar Ends
Odyssey Par Ends
Headset
1-1/8" sealed, integrated
Cranks
3-piece tubular chromoly, 8-splined, 175mm
Sprocket
Verde design, 25T
Bottom Bracket
Mid, sealed
Pedals
Odyssey Twisted PC
Chain
Taya teflon, black
Driver/Freewheel
9T sealed driver
Front Rim
Cinema 777, double wall
Rear Rim
Front Hub
36 hole, sealed bearing, 3/8" chromoly axle
Rear Hub
36 hole, sealed bearing, 14mm chromoly axle
Front Tire
DUO Stunner, 2.20"
Rear Tire
DUO Stunner, 2.20"
Spokes
Black
Seat
Verde slim Pivotal w/color matching PVC patch
Seatpost
Integrated
Seatpost Clamp
N/A
Brakes
Tektro 907
Brake Levers
Alloy lever, black
Detangler
N/A
Cable
Standard brake cable
Pegs
2 pieces, steel
Colors
Chrome or flat black
Weight
24 lb 4 oz (11.0 kg)
KINK LIBERTY 2011
* Colours: Trans Red
* Weight: 24lb 12oz
* Frame Spec: 20.5" Top Tube, 13.75" Chain Stay
* Forks: Kink Strife Fork 100% Chromoly Steerer Tube w/ Tapered Legs
* Bars: Kink 8" Uptown Bars
* Grips: Kink Alpha Grips w/ Kink Drive Barends
* Stem: Mission Converge Stem
* Headset: Mission Integrated Sealed Headset
* Seat: Kink Rival Pivotal
* Post: Mission Pivotal Seat Post w/ Slim Seat Clamp
* Hubs: F - Mission Echo Sealed, R - Mission React Sealed Cassette Hub w/ 9t Driver
* Rims: F - Alienation Black Sheep, R - Alienation Black Sheep
* Tires: F - Kenda Kontact 20x2.25", R - Kenda Kontact 20x2.25"
* Cranks: 3pc Tubular Chromoly Cranks w/ Mission Sealed Mid BB
* Pedals: Odyssey Twisted PC Pedals
* Chain: KMC 510HX
* Sprocket: Kink Aluminum 25t Decimal Sprocket
* Pegs: 4 Steel Pegs
