975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 01:29 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Wheel spokes- HELP!
Author Topic: Wheel spokes- HELP!  (Read 1566 times)
Offline Hiro Tonka
Wheel spokes- HELP!
« on: December 06, 2010, 05:57 PM »
I'm going to atempt to respoke some Z rims with some ACS low flange hubs. I've never done this before, can you guys help?
Uncertain which size spokes/nips to buy. I'm just after some normal spokes, can you help and maybe cut and paste a link for some on Ebay that are at the right price.
I don't want to get the wrong ones.
Thanks
Offline Hiro Tonka
Re: Wheel spokes- HELP!
« Reply #1 on: December 06, 2010, 06:11 PM »
Nice one, thanks for that.
Just out of interest does anyone know how much it'll cost me to get these done at a bike shop, including spokes?
« Reply #2 on: December 06, 2010, 06:23 PM »
I wouldn't immediately go for 194mm spokes.  It mainly depends on what lacing pattern you are going for 3x or 4x.
Offline Munnyella
« Reply #3 on: December 06, 2010, 07:08 PM »
I generally get my spokes from custom riders, they have a good range, never been out of stock on anything i've wanted and sell individually, so you only buy what you need.
They are really helpful too, and usually arrive within 2 days.
motomagII
« Reply #4 on: December 06, 2010, 07:10 PM »
very true as most my wheels are laced 3 cross wqhich would be i believe 188mm spokes or 186 with long nipples
« Reply #5 on: December 06, 2010, 07:28 PM »
I think I use 184mm for a 3x lacing on Z-Rims as the rims have a raised section in the middle where the spokes sit.
« Reply #6 on: December 06, 2010, 07:36 PM »
Tell em Gaz
« Reply #7 on: December 06, 2010, 07:38 PM »
ive just done a set with acs large flange hubs and used 184 spokes with a 3x pattern so i wouldnt use these, the other 2 sets ive had done had low flange hubs and 194 spokes with a 3x pattern id be tempted to go with these as they work :D
« Reply #8 on: December 06, 2010, 07:39 PM »
« Reply #9 on: December 06, 2010, 11:14 PM »
So Gaz 184 3 cross works well then ( slightly long at the rim tape side or not )
I'm sure when my Z's were done for my Quadangle (4 years ago mind ) they were a bit long and thought maybe 182's next time
I could be wrong , as this was before going to Craig garage for a lobotomy  :D
« Reply #10 on: December 06, 2010, 11:18 PM »
the spokes are deffo 184, 3x and have gone on large flange acs stoker hubs, they fit just fine my furry lickle squirrell :D
« Reply #11 on: December 06, 2010, 11:32 PM »
Just buy something from this century or at the least from the end of last century and stop fucking around with playdough and odd looking metal  :4_17_5:
« Reply #12 on: December 06, 2010, 11:32 PM »
Thanks Gaz
I might just boil some up , all twisty like ,delve my hand into a box of random spokes 181,184, 182, 186's
and drop them off at Fox's cycles
and ask for the hub decals to be lined up facing Mecca
and the valve holes line up exactly 2 degrees west of magnectic north   :angel:  :D
« Last Edit: December 06, 2010, 11:35 PM by Hunterdubber »
« Reply #13 on: December 06, 2010, 11:44 PM »
Michael Hutchins time :)
« Reply #14 on: December 07, 2010, 12:26 AM »
Take the wheels down into the shop dungeon to build  ::)
and then get the following
One of these
and one of these
and some of this
and jack off with a few mouthfuls of these
and it'll be just like being in Sydney hotel room 1997
Then open your eyes ,, the wheels won't be done , and all the customers will have probably left the shop.
But mentally you be in a better place  :D  ;D
Offline Hiro Tonka
« Reply #15 on: December 07, 2010, 06:44 PM »
You guys really do scare me sometimes  ;D
Thanks for "nearly all" your advice
Offline poolysheriff
« Reply #16 on: December 18, 2010, 05:48 PM »
Right i,m building up some Araya Aero's 1.75
Onto Suzue small flange hubs
3x
What size of spoke am i too use for these ?
I bought 194mm but i think they are too long  :-\
crightonk
« Reply #17 on: December 18, 2010, 11:02 PM »
Was gonna have a go at a set of wheels but I'm more confused now than when I started reading the thread  :LolLolLolLol: :LolLolLolLol:
« Reply #18 on: December 18, 2010, 11:07 PM »
3x
i built up those black rims you sold me gaz, 3x on small flange suzue hubs, i used 194 mm on the front but for some reason on the rear they were too long, so ended up using 188mm which worked fine :D
hope this helps :daumenhoch:
