975755
TattooedYorkie
September 22, 2024, 08:12 PM
primo hollowbites----pedal insert in crank arms
Topic: primo hollowbites----pedal insert in crank arms (Read 1391 times)
calmac
December 03, 2010, 05:19 PM »
Got a spinning insert, is there a special tool to hold the insert whilst removing pedal as it has 2 insert slots,(tried caliper pliers i have but they're too weak), or any other ideas guys ?
THANKS
cALUM
Dark Diggler
Berm Worm
Re: primo hollowbites----pedal insert in crank arms
December 03, 2010, 05:51 PM »
As a last resort you could drill a small hole in the end of the crank arm that goes all the way to the insert, tap it and put a grub screw in it to secure the insert, it should be fine long term
calmac
December 04, 2010, 01:07 PM »
SORTED
Anyone else gets this problem,get some Shock & Unlock from Halfords, forgot i had it in the shed,AMAZING stuff, frees of most anything that's seazed up.
Just sprayed,left overnight & gave it a good solid crack with a mallet on the pedal spanner
Calum
