975755
TattooedYorkie
September 21, 2024, 06:02 PM
Actual rim diameter ?
Topic: Actual rim diameter ? (Read 1961 times)
hosburger
November 30, 2010, 11:40 AM »
Hi, I need to know the outside diameter of a 20" wheel rim. I have some tuff wheels that I need to dye and am work trying to find a container big enough.
HEYWOOD BMX
Re: Actual rim diameter ?
November 30, 2010, 01:21 PM »
A tape measure.
spesh
November 30, 2010, 03:36 PM »
wickes do a garden tub big enuff
+ you can get ya cheap bleach there too
http://www.wickes.co.uk/Mixing-Tub/invt/198840
Munnyella
Look Back
November 30, 2010, 03:41 PM »
You need about 16 1/2 inches, but bigger would be better for dying, so you can slosh it around a bit, For bleaching I used a box lined with polythene, but you are gonna be using very hot water with dye, so don't use the box method!!
hosburger
December 01, 2010, 12:45 PM »
nice one. Thanks for the mixing tub info too.
