975884 Posts in 138950 Topics by 6383 Members - Latest Member: moley147 February 17, 2025, 06:05 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Advice - changing the alloy hub in a tuff wheel
Author Topic: Advice - changing the alloy hub in a tuff wheel  (Read 1060 times)
toooldforthis
« on: April 28, 2006, 08:47 AM »
I am looking to swap a hub from one tuff to another, is it difficult to do?
Aren't the hubs riveted on??
Paul
Coastvl
Re: Advice - changing the alloy hub in a tuff wheel
« Reply #1 on: April 28, 2006, 09:05 AM »
Yes they are. They are almost impossible to reproduce. I did say ALMOST! Everyone just uses bolts to replace them now. I done my first one back in 1980! Grind the heads off and punch them through.
Offline BrianP
« Reply #2 on: April 28, 2006, 09:22 AM »
Gotta make sure you grind off or drill off the original rivet head and not the end which was rivetted, since the rivetted end will have flared during the rivetting process and it's a bugg*r to try and pull this through the plastic and you also risk damaging the holes for the hub.
Drilling off the original rivet heads means you're pulling the wider rivetted end away from the hub as opposed to through it.
Does that make sense?
Offline ORB
« Reply #3 on: April 28, 2006, 09:27 AM »
give me ten,
I will post up a scan of the guide how to do it.
Drilling is better than grinding though. I have done a few ;)
12
Offline ORB
« Reply #4 on: April 28, 2006, 09:45 AM »
Here we go.
And here is the freewheel guide, just because i can.
12
toooldforthis
« Reply #5 on: April 28, 2006, 09:54 AM »
 :4_17_5:
Cheers Fellas, Nice One!
As usual  8)
Donker
« Reply #6 on: April 28, 2006, 02:06 PM »
im thinking i could make some of those rivets, or supply material long enough to allow you to rivet both ends.
anyone interested in trying? id need the diameter(accuratly measured) of the material used :uglystupid2:
Offline BrianP
« Reply #7 on: April 28, 2006, 03:44 PM »
Dunno about the diameter exactly, but M4 threaded rod with a nyloc nut on each end has always got me out of a hole...
