975926 Posts in 138954 Topics by 6389 Members - Latest Member: The Docmeister April 18, 2025, 04:34 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  skyways arrived today, struggling to get them on the forks though
Author Topic: skyways arrived today, struggling to get them on the forks though  (Read 4830 times)
evening all
my new skyways arrived today  :) got them straight out the box and went to try them on the frame, but found a slight problem
they fit in the rear dropouts no probs, but the forks are another matter - while they are defo the right size the fork dropouts are thinner near the end and wider where the axle should sit. they don't want to go on with mild force but i haven't tried whacking them in or filing anything down
I did wonder if it's the powder coat, but don't want to really force them on and risk messing up the finish, although might not have a choice
is this normal with haro forks? I think the previous owner ( harorider ) had new school tuffs on there before and can't see any damage...
thought i'd better ask before I go and mess up SBDs fine workmanship
cheers
Re: skyways arrived today, struggling to get them on the forks though
« Reply #1 on: November 10, 2010, 09:18 PM »
has'nt the wheel axles got the flat spots on them ?.
if not its either change em out for the right sort.or get the file out and take a little bit out ya forks  :D
« Reply #2 on: November 10, 2010, 09:19 PM »
Old school forks are designed to have flat axles, just file them a little bit where they go in the dropouts.
« Reply #3 on: November 10, 2010, 09:25 PM »
As said twice you will need to file them down.  You might want to cut them down aswell as they are normally long.  Leave the nuts on if you cut them down as they will clean the threads up when you take the nuts off. :daumenhoch:
Offline HUTCHMAN
« Reply #4 on: November 10, 2010, 10:03 PM »
pop over again bud if you need a hand!
Offline 58 delray
« Reply #5 on: November 10, 2010, 10:16 PM »
HANG ON BEFORE YOU FILE ANYTHING
are these the new school graphites you were on about, if so just take the allen head axle bolts out, put the wheel in place in the forks and then put the allen head axle bolts in with the correct washers that should have come with them  :daumenhoch:
« Reply #6 on: November 10, 2010, 10:38 PM »
Thanks guys
no flat spots on the axles - they're just threaded all the way along, thought I'd be ok with 10mm axles  ::)
are there different axles available for NS tuffs as well as this type?
as brettypeeps said they're also a bit on the long side!
my toolkit's not really up to the job, plus tbh I'm a bit nervous about fooking up a brand new wheel
dave if you fancy giving me a hand sometime I'd be very grateful  :daumenhoch:
cheers
Offline HUTCHMAN
« Reply #7 on: November 10, 2010, 10:41 PM »
give us a shout when's convient. :daumenhoch:
« Last Edit: November 10, 2010, 10:46 PM by HUTCHMAN »
« Reply #8 on: November 10, 2010, 10:43 PM »
Don't worry Griff... I'm the man for the job  :D
« Reply #9 on: November 10, 2010, 10:46 PM »
no mate they're regular black tuffs - the guy selling graphites relisted em for 175 quid!
the axles don't have allen heads in them, just a bolt and washer - need to get some more washers too to space em out a bit methinks
don't worry I'm not going to file anything! (no file for a start  ;D )
cheers
Offline HARORIDER
« Reply #10 on: November 10, 2010, 10:57 PM »
just seen this,i did have new school tuffs on and axles went in ok although i did have to pull forks apart slightly to allow for washers but thinking about it was there a thing about the new school tuffs having 2 different types of axles fitted :-\
« Reply #11 on: November 10, 2010, 11:01 PM »
haha Ed you mad fooker - that's a great pic tho
« Reply #12 on: November 10, 2010, 11:06 PM »
The 2010 wheels have new axles fitted in them because the guy that ordered them for the UK (Distributer) insisted they come with ridiculous axles.  I had a chat with skyway earlier this year about it and they told me all about it.  it is either a new axle or file and cut unfortunately :knuppel2:
« Reply #13 on: November 10, 2010, 11:10 PM »
If I line up the wheel to the forks it looks like it needs some spacers in there (I thought the washer and nut should go on the outside so the nut doesn't grind off the paint when I tighten it)
Offline HARORIDER
« Reply #14 on: November 10, 2010, 11:15 PM »
they do but some people also put thin washers on the inside too to prevent chewed up drop outs hence why the haro ones were pretty good :daumenhoch:
« Reply #15 on: November 10, 2010, 11:19 PM »
there's plenty of room inside - someone must have pulled em apart  :LolLolLolLol:
on the lookout for 10mm washers  ;D
Offline HUTCHMAN
« Reply #16 on: November 10, 2010, 11:21 PM »
got a bag full of em!!
« Reply #17 on: November 10, 2010, 11:25 PM »
On my master I have washers on both inside and outside of the frame and forks.  8x washers on total .  I got some if Hutchman cant help you out :daumenhoch:
« Reply #18 on: November 10, 2010, 11:31 PM »
swap for some Leffe?
« Reply #19 on: November 11, 2010, 09:20 AM »
Files are for girls... ANGLE GRINDERZ mmm  :smitten:
got my new school axles to fit my old school bike  >:D
sweetbeats
« Reply #20 on: November 11, 2010, 09:27 AM »
Took mine to a local engineer cut all 4 axels shorter and filed the front-job done £5  :daumenhoch:
Offline 58 delray
« Reply #21 on: November 11, 2010, 09:44 AM »
griff, do you have some pics of the problem?
« Reply #22 on: November 11, 2010, 09:50 AM »
could always try these?  but as usual wankstanlys doesn't have any in stock (now there's a surprise!)
http://www.winstanleysbmx.com/product/36653/Skyway_1365mm_x_38_Front_Axle_wFlat_Spot
« Reply #23 on: November 11, 2010, 01:58 PM »
I doubt it Rob, W4nstanleys stock system works in reverse; they have stock when the computer says No and no stock when the computer says Yes  :LolLolLolLol:
« Reply #24 on: November 11, 2010, 02:07 PM »
off to see the hutchman later  :daumenhoch:
am sure it will be fixed but there's always the new axle option, thanks to all for your advice
love this site
