975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 12:26 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  De-Chroming ?
Author Topic: De-Chroming ?  (Read 4914 times)
Gaylord
De-Chroming ?
« on: October 23, 2010, 04:25 PM »
Don't  know if its possible and might be a stupid question but ?
Can you remove Chrome from an Alu frame thats been Chromed badly ?
i bought a F/F with redline flights fitted off gaybay and when i removed the b/b i then realised they had filed the b/b cups down to fit into the frame as the chrome plating had gone inside
and that the chrome on the  rear triangle of the frame was starting to peel off in big flakes  :tickedoff:
so i started to peel more off the rear triangle (it was like peeling flakey sunburnt skin off your arms i just couldn't stop myself) till i got to the point where no more would come off
so now i'm left with a frame thats half chrome half bare alu  :'(
So i'm sending out an S O S
Regards Gaylord
Re: De-Chroming ?
« Reply #1 on: October 23, 2010, 04:27 PM »
really you need to send it to a chromer to strip.removing chrome isnt as simple as paint,youre lucky you got as far as you did,im afraid its a trip to a chromers now ,apparently they have to reverse the process,hope this helps  :daumenhoch:
Re: De-Chroming ?
« Reply #2 on: October 23, 2010, 04:30 PM »
Are you sure it's an alloy frame?  They don't usually chrome alloy frames as the alloy oxidises and peels/flakes.  You can definitely get it removed, it's a reverse process and whatever you do DO NOT GET IT BEAD BLASTED as you will fook the frame  :shocked:.  There's a few threads in here (see the stickies) about chromers so you should be able to find on close/not far from you  :daumenhoch:
Gaylord
Re: De-Chroming ?
« Reply #3 on: October 23, 2010, 04:45 PM »
Thanks for that chaps  :daumenhoch:
it sounds expensive, but it'l have to be done then powder coated me thinks
will post some picks when i get it all sorted, unless the chromes hiding a dark secret  ::)
Offline Glynnyboy
Re: De-Chroming ?
« Reply #4 on: October 23, 2010, 05:24 PM »
I really don't know what a chromer would suggest here. I know a guy that uses 2 chromers , one blast strips and the other chemically strips. The chrome it's self is stripped by reverse polarity but then you have the nickle to contend with. If your wanting to get it down to the frames original composit i.e the alloy as you say here then the nickle has to be stripped. That's done in a chemical strip bath and can be very invasive. It can increase any pitting under the chrome/nickle plate of a rusted chromolly or steel frame. So i don't know where you would stand with an alloy frame as the nickle plating would be harder than the alloy.
It's not the chrome your going to have to worry about it's the nickle on alloy.
If your frame is chromolly then no problem because the chromolly steel composite is harder than nickle. I believe the process is called Strip and pickle.(strip = the reverse polarity de chrome ...... pickle = the chemical pickle of the frame to strip away the nickle )
b45t4rd
Re: De-Chroming ?
« Reply #5 on: October 23, 2010, 05:36 PM »
Never seen a chromed aluminium frame before, stick a pic up. ???
Gaylord
Re: De-Chroming ?
« Reply #6 on: October 24, 2010, 09:26 AM »
I will try and get some pics up as soon as I work out how to do that  :buck2:
And Glynnyboy  your right there is nickel plating underneath the chrome
And if the process to remove it won't harm the frame then I think I will go for that
So I could have a polished finish to the frame
Gaylord
Re: De-Chroming ?
« Reply #7 on: October 24, 2010, 07:43 PM »
Here's a few pics of the flaking chrome frame
<a href="http://s838.photobucket.com/albums/zz310/chewy66_123/?action=view&current=flovalflyer003-1.jpg" target="_blank"><img src="http://i838.photobucket.com/albums/zz310/chewy66_123/flovalflyer003-1.jpg" border="0" alt="floval">[/url]
Re: De-Chroming ?
« Reply #8 on: October 25, 2010, 10:25 AM »
First time i've seen a chrome one of them, i wonder if it's factory?  ???
Offline bmxr
Re: De-Chroming ?
« Reply #9 on: October 25, 2010, 10:58 AM »
You could mirror polish the exposed alu to get a similar finish as the remaining chrome.
Chromed alu never has the same mirror finish as plated 4130; if it looks shit then get it stripped............or if you're getting it powder coated, just sand the chrome to get a key, then apply the powder/paint.  It'll save you the ball-ache of a trip to the de-chromers
M5AT
Re: De-Chroming ?
« Reply #10 on: October 25, 2010, 11:05 AM »
Yeah, what he said.
My Ripper looks like its been stripped & polished, has chrome forks & there int much difference between the frame & the forks finish wise.
http://www.radbmx.co.uk/forum/index.php'topic=107807.0
Only a show bike though so its never exposed to the elements.
But its been hung up in me office for a few years now, & hasnt appeared to lost any of its shine.
Gaylord
Re: De-Chroming ?
« Reply #11 on: October 25, 2010, 05:24 PM »
I think i'm gonna strip it
i need to know whats under the chrome ?
has it been chromed for a reason is it hiding something
or am i just being paranoid :buck2:
by the way nice bikes M5AT   :daumenhoch:
Re: De-Chroming ?
« Reply #12 on: October 25, 2010, 07:26 PM »
Chrome's not going to hide anything mate.
Re: De-Chroming ?
« Reply #13 on: October 25, 2010, 09:48 PM »
Oooh, that's odd and rare.
Well... it is while the chrome is still on it.
Gaylord
Re: De-Chroming ?
« Reply #14 on: October 25, 2010, 11:14 PM »
Yeh a bit like myself  ;D
Re: De-Chroming ?
« Reply #15 on: October 26, 2010, 06:10 AM »
Yes, because it looks cool  :coolsmiley:
