975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 11:52 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  fitting stickers
Author Topic: fitting stickers  (Read 737 times)
Offline kev-s
fitting stickers
« on: October 22, 2010, 10:24 AM »
any tips?
my frame is at the powdercoaters and i have a new sticker set for when it comes back
the main thing is the downtube sticker is all in one and wraps around the downtube and i dont wanna mess it up and get creases/wonky/air bubbles etc...
Re: fitting stickers
« Reply #1 on: October 22, 2010, 10:35 AM »
have a hairdryer at the ready and when doing this type of sticker i try and just stick down the very middle of the sticker on the down tube first ( literally just about 5mm straight down the middle of it )  you can then see if it is central and far les chance of air bubbles plus you can move it a lot easier if you aint happy. then work your way from the inside out each side at a time
hope that makes sense as works for me. if you do c0ck it up give a gentle heat with the dryer before trying to pull it off as you could pull powder with it ( also something i have done  :( ) but be careful not to stretch it as the heat also softens the sticker
good luck
« Last Edit: October 22, 2010, 10:38 AM by Brummie »
« Reply #2 on: October 22, 2010, 10:43 AM »
I use a 5 to 10% fairy liquid solution in a bowl and run the sticker through it.
This allows the sticker to slide to where you want it.
I then use a soft dry cloths th squeeze the solution out and It has never gone wrong for me yet  :daumenhoch:
There is another method along the same Idea which is to put the soap solution on the frame, but I have not done this foe feaar of a dry spot and the sticker getting damaged :uglystupid2:
« Last Edit: October 22, 2010, 12:01 PM by brettypeeps »
Offline jimwise68
« Reply #3 on: October 22, 2010, 10:47 AM »
As mentioned above, and once you have done it you will wonder what all the fuss was about  :daumenhoch:
trasher
« Reply #4 on: October 22, 2010, 11:20 AM »
I use a little spray of windowlean
Never failed
As  above you can still move the decal around
Then wipe over to get rid of the solution
But remember to hold the decal as you wipe so it doesn't move
Offline kev-s
« Reply #5 on: October 22, 2010, 11:30 AM »
cheers guys ill give the windowlean a go once i get the frame back :daumenhoch:
« Reply #6 on: October 22, 2010, 12:03 PM »
gunna give this a try on my new chrome LG's when they arrive, i've got some original LG decals for em but they look like a right fooker to put on right where the forks bend  :-\
trasher
« Reply #7 on: October 22, 2010, 01:18 PM »
Did the windowlean method on my lg's rob
Just be careful when wiping as each one can move
« Reply #8 on: October 22, 2010, 01:28 PM »
these are full decals not the rub on ones (or was that what you meant?)  :)
monkian
« Reply #9 on: October 22, 2010, 07:27 PM »
A squirt of Johnsons No More Tears Shampoo in some water and one of them plant sprayers :daumenhoch:
Be kind to your decals.
« Last Edit: October 22, 2010, 07:30 PM by monkian »
