975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 02:33 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Shimano Tourney Calipers F&R?
Author Topic: Shimano Tourney Calipers F&R?  (Read 1122 times)
monkian
« on: October 04, 2010, 11:18 AM »
Ok, I just bought a NOS pair but they both have the same length spindles (approx 80mm).
On the back of the arms, one is stamped 88S / PC the other 79S / NF
If I have a front and rear set, anyone know whats what? :buck2:
Also, can you fit the Tourney Quick Release Mechanism to standard calipers :D
Thanks in advance, Paul :daumenhoch:
« Last Edit: October 04, 2010, 11:40 AM by monkian »
Offline stevochb
Re: Shimano Tourney Calipers F&R?
« Reply #1 on: October 04, 2010, 01:58 PM »
Alright Paul.
I have a nos rear caliper that is stamped 88s, not got a front to compare it with though.
monkian
« Reply #2 on: October 04, 2010, 02:09 PM »
Cool, thanks man. That's got the ball rolling :daumenhoch:
« Reply #3 on: October 04, 2010, 05:43 PM »
Pics ?  ???
Got quite a few tourneys here I'll take a look at mine.
Are both centre bolts threaded all the way ?  ???
monkian
« Reply #4 on: October 04, 2010, 05:50 PM »
Thanks man. If you could check the bolt length that would be great :daumenhoch:
Neither of them are completely threaded. I'm thinking they've both got fronts :-\
Don't know what 88S / PC & 79S / NF mean unless: date / ??
« Last Edit: October 04, 2010, 05:55 PM by monkian »
Offline Munnyella
« Reply #5 on: October 05, 2010, 05:50 PM »
I've got a tourney rear spindle you can have. the caliper got nicked with the haro, but i'd got the spindle on the bench!
I know nothing about them, whether it'll fit or not, but you are welcome to it.
PM me
Mark
monkian
« Reply #6 on: October 05, 2010, 05:56 PM »
PM me
Mark
You're a Gent :daumenhoch:
PM on the way. Thanks man.
Offline sparky
« Reply #7 on: October 05, 2010, 10:10 PM »
The correct length is approx 65mm rear and 80mm front. Both of mine are stamped 88S. :daumenhoch:
monkian
« Reply #8 on: October 05, 2010, 10:30 PM »
Cheers Mark :daumenhoch:
I think they were first available from 79 so that might explain the stamps. Looks like I've got an odd pair of fronts ::)
Still, they'll soon be sorted thanks to Mark M :daumenhoch:
