975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 29, 2024, 03:55 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Bleaching Tuffs
Author Topic: Bleaching Tuffs  (Read 899 times)
Offline Macmania
Bleaching Tuffs
« on: September 24, 2010, 05:08 PM »
Sure this has been covered before, but can anyone point me in the right direction to where I can find some info out about this ?  :) Thanks in advance. Nath  :)
Wanted: Anything MT Racing
Offline fischflo
Re: Bleaching Tuffs
« Reply #1 on: September 24, 2010, 05:14 PM »
check it out http://www.radbmx.co.uk/forum/index.php'topic=17050.0 ...still the mother of all TUFF bleach/dye threads?  :fart:
EDIT:
might want to skip all the sillies and start from here
http://www.radbmx.co.uk/forum/index.php'topic=17050.msg1026513#msg1026513  :daumenhoch:
« Last Edit: September 24, 2010, 05:23 PM by fischflo »
Offline Macmania
Re: Bleaching Tuffs
« Reply #2 on: September 24, 2010, 05:54 PM »
I assume that you have to dilute the bleach, what ratios etc ?  :-\
Offline Steve P
Re: Bleaching Tuffs
« Reply #3 on: September 24, 2010, 06:03 PM »
Here you go Nath ... works every time for me  :daumenhoch:
1. Scrub each wheel well with a cream cleanser like Cif and rinse well
2. Grease hubs well or use a good quality PVC tape to mask them up (or both - tape then grease)
3. Soak in neat bleach and leave for 24hrs
4. Remove each wheel and repeat step #1
5. Check hub masking and repeat step 2 if required
6. Return to the bleach and leave to soak for another 24hrs
7. Repeat steps 4, 5 and 6 until you're happy with the finish
Steve
Offline Macmania
Re: Bleaching Tuffs
« Reply #4 on: September 24, 2010, 06:16 PM »
Thanks guys, neat bleach it is then  :daumenhoch:
chichi
Re: Bleaching Tuffs
« Reply #5 on: September 25, 2010, 12:25 AM »
Just make sure when you have the finish you want, the wheels are well rinsed. As I was in a rush a couple of months back to take a bike to a show & now I am scrubbing a rusty freewheel!  doh chichi ya fool....
Yeah, so all the bleach needs to be removed or it will keep munching on them Skyways & anything else close by..
