975822 Posts in 138946 Topics by 6374 Members - Latest Member: Boults December 26, 2024, 12:46 AM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  skyway alloy hub pushed - rejig it in any way ???
Author Topic: skyway alloy hub pushed - rejig it in any way ???  (Read 416 times)
« on: September 21, 2010, 08:39 PM »
I have a rear red skyway alloy hub - trouble is it has the dreaded pulled too tight shite
I have looked at it and it doesn't seem that bad - the rear freewheel came of sweet - now my question is, has any one tried to knock or pull it straight ? the rivets look ok and it seems that it they could be pushed or pulled back into shape, then it could be lined up straight into shape ? rejigged sort of
will get a pic up - but in the mean time if any one has any info that would help !
cheers B  :laugh:
Offline Wadz
  • Ride Ride Ride!!
Re: skyway alloy hub pushed - rejig it in any way ???
« Reply #1 on: September 21, 2010, 09:35 PM »
can't you tap it gently back from the inside with a long punch or a cut down broom handle as not to mark the inside off the hub, make sure you tap it at different positions so you knock it out evenly. not done one as yet but got one to do and read something awhile ago that this was the way to go ;)
Offline beard1973
« Reply #2 on: September 21, 2010, 09:39 PM »
I am sure Mark (cbrgil) Restrospect has a tool for doing just this job....
« Reply #3 on: September 22, 2010, 01:09 PM »
Yep, haven't been to see Mark for ages but he has indeed got a tool for this. Was based on a fly-wheel puller I think.
