975755
TattooedYorkie
September 22, 2024, 03:33 AM
brazing with refillable butane blowtorch??
Topic: brazing with refillable butane blowtorch?? (Read 1979 times)
firebird4130
September 07, 2010, 03:49 PM »
would it be possible to do some brazing with a refillable blowtorch that uses lighter gas?
Fraz
snav69
Re: brazing with refillable butane blowtorch??
September 07, 2010, 03:55 PM »
I would say Yes
as we used something simillar at school
Sawzall is your man to ask though
firebird4130
September 07, 2010, 04:55 PM »
cool, I'll give it a go then, Got some bars I want to extend
steve69
Flip-Whip
aka. Steve Changa
September 07, 2010, 09:45 PM »
Hi Fraz, If there not chrome send them up to me and i'll weld a bit on for you.
You got my address
firebird4130
September 07, 2010, 11:02 PM »
cheers for the offer mate, they are chrome though, does that make em harder to weld?
steve69
Flip-Whip
aka. Steve Changa
September 08, 2010, 09:13 AM »
you would need to grind off/remove the chrome to weld it, no major problem if your using them as it would be covered by the grips
LMK, cheers Steve.
firebird4130
September 08, 2010, 10:05 AM »
cheers for the advice mate I'll be sure to grind the chrome down on that area, I've ordered the blowtorch now will lt you know how it goes
steve69
Flip-Whip
aka. Steve Changa
September 08, 2010, 10:35 AM »
you know where i am if it doesn't work out
firebird4130
September 08, 2010, 10:46 AM »
cheers mate
no doubt you'll be hearing from me
HUTCHMAN
540 Air
September 08, 2010, 10:57 AM »
bear in mind you'll have to achieve temperatures above 840 F.
firebird4130
September 08, 2010, 02:16 PM »
so this is doomed to failure?
mattfx81
Cherry Picker
Reply #11 on:
September 08, 2010, 02:27 PM »
If they are for a rider then you would best go for a fused joint and get them welded using mig or tig.
